double GetRangeMaximum(unsigned int idx)
Returns the range minimum/maximum value, is exists, otherwise 0 is returned.
int SetDefaultValues(vtkSMProperty *prop, bool use_unchecked_values) override
represents a ranged vtkSMTransferFunctionProxy
static vtkSMProxyListDomain * New()
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
double GetRangeMinimum(unsigned int idx)
