represents a ranged vtkSMTransferFunctionProxy More...
#include <vtkSMRangedTransferFunctionDomain.h>
| typedef vtkSMProxyListDomain | Superclass |
Public Types inherited from vtkSMProxyListDomain | |
| typedef vtkSMDomain | Superclass |
Public Types inherited from vtkSMDomain | |
| enum | IsInDomainReturnCodes { NOT_APPLICABLE = -1, NOT_IN_DOMAIN = 0, IN_DOMAIN = 1 } |
| double | GetRangeMinimum (unsigned int idx, int &exists) |
| Return a range min. More... | |
| double | GetRangeMaximum (unsigned int idx, int &exists) |
| Return a range max. More... | |
| int | SetDefaultValues (vtkSMProperty *prop, bool use_unchecked_values) override |
| If prop is a vtkSMProxyProperty containing a vtkSMTransferFunctionProxy this set its range based on this domain min and max values. More... | |
| bool | GetRangeMinimumExists (unsigned int idx) |
| Returns if range minimum/maximum bound is set for the domain. More... | |
| bool | GetRangeMaximumExists (unsigned int idx) |
| double | GetRangeMinimum (unsigned int idx) |
| Returns the range minimum/maximum value, is exists, otherwise 0 is returned. More... | |
| double | GetRangeMaximum (unsigned int idx) |
Public Member Functions inherited from vtkSMProxyListDomain | |
| const std::vector< ProxyType > & | GetProxyTypes () const |
| Returns a vector of proxy types for the proxies in the domain. More... | |
| unsigned int | GetNumberOfProxyTypes () |
| Returns the number of proxies in the domain. More... | |
| const char * | GetProxyGroup (unsigned int index) |
| Returns the xml group name for the proxy at a given index. More... | |
| const char * | GetProxyName (unsigned int index) |
| Returns the xml type name for the proxy at a given index. More... | |
| const char * | GetProxyName (vtkSMProxy *proxy) |
If the proxy is part of the domain, then this returns the name used for the proxy in the domain. More... | |
| vtkSMProxy * | GetProxyWithName (const char *pname) |
Inverse of GetProxyName, returns the first proxy with the given name. More... | |
| int | IsInDomain (vtkSMProperty *property) override |
| This always returns true. More... | |
| void | AddProxy (vtkSMProxy *) |
| Add a proxy to the domain. More... | |
| bool | HasProxy (vtkSMProxy *) |
| Returns if the proxy is present in the domain. More... | |
| unsigned int | GetNumberOfProxies () |
| Get number of proxies in the domain. More... | |
| vtkSMProxy * | GetProxy (unsigned int index) |
| Get proxy at a given index. More... | |
| vtkSMProxy * | FindProxy (const char *xmlgroup, const char *xmlname) |
| Find a proxy in the domain of the given group and type. More... | |
| int | RemoveProxy (vtkSMProxy *proxy) |
Removes the first occurrence of the proxy in the domain. More... | |
| int | RemoveProxy (unsigned int index) |
| Removes the proxy at the given index. More... | |
| void | CreateProxies (vtkSMSessionProxyManager *pxm) |
| Creates and populates the domain with the proxy-types. More... | |
| A vtkSMProperty is often defined with a default value in the XML itself. More... | |
| void | SetLogName (const char *prefix) |
| Sets log name for each of the proxy in the domain using the prefix provided. More... | |
| virtual void | SetDefaultIndex (unsigned int) |
| Set and Get the default proxy index. More... | |
| virtual unsigned int | GetDefaultIndex () |
Public Member Functions inherited from vtkSMDomain | |
| Is the (unchecked) value of the property in the domain? Overwritten by sub-classes. More... | |
| virtual void | Update (vtkSMProperty *requestingProperty) |
| Update self based on the "unchecked" values of all required properties. More... | |
| Set the value of an element of a property from the animation editor. More... | |
| Provides access to the vtkSMProperty on which this domain is hooked up. More... | |
| Helper method to get the number of input connections hence the number of available vtkPVDataInformation from input proxy connected to the required property with the given function. More... | |
| Returns a given required property of the given function. More... | |
| When the IsOptional flag is set, IsInDomain() always returns true. More... | |
| Helper methods to get vtkPVDataInformation from input proxy connected to the required property with the given function and provided input index. More... | |
| virtual vtkPVDataInformation * | GetInputDataSetInformation (const char *function, unsigned int index=0) |
| virtual vtkPVDataInformation * | GetInputSubsetDataInformation (unsigned int compositeIndex, const char *function, unsigned int index=0) |
| virtual vtkPVDataInformation * | GetInputSubsetDataInformation (const char *selector, const char *assemblyName, const char *function, unsigned int index=0) |
| static vtkSMRangedTransferFunctionDomain * | New () |
| static vtkSMRangedTransferFunctionDomain * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMProxyListDomain | |
| static vtkSMProxyListDomain * | New () |
| static vtkSMProxyListDomain * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMDomain | |
| static vtkSMDomain * | New () |
| static vtkSMDomain * | SafeDownCast (vtkObject *o) |
| vtkSMRangedTransferFunctionDomain () | |
| ~vtkSMRangedTransferFunctionDomain () override | |
| int | ReadXMLAttributes (vtkSMProperty *prop, vtkPVXMLElement *element) override |
| void | InvokeDomainModifiedEvent () |
| Callback to invoke DomainModified event. More... | |
Protected Member Functions inherited from vtkSMProxyListDomain | |
| vtkSMProxyListDomain () | |
| ~vtkSMProxyListDomain () override | |
| void | AddProxy (const char *group, const char *name) |
| Adds a proxy type, used by ReadXMLAttributes(). More... | |
| void | ChildSaveState (vtkPVXMLElement *propertyElement) override |
| Save state for this domain. More... | |
| int | LoadState (vtkPVXMLElement *domainElement, vtkSMProxyLocator *loader) override |
| void | SetProxies (vtkSMProxy **proxies, unsigned int count) |
Protected Member Functions inherited from vtkSMDomain | |
| vtkSMDomain () | |
| ~vtkSMDomain () override | |
| Load the state of the domain from the XML. More... | |
| Remove the given property from the required properties list. More... | |
| Add a new required property to this domain. More... | |
| void | DomainModified () |
| Invokes DomainModifiedEvent. More... | |
| void | InvokeModified () |
| Gets the number of required properties added. More... | |
| Set the domain's property. More... | |
| Add the header and creates a new vtkPVXMLElement for the domain, fills it up with the common attributes. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Protected Attributes inherited from vtkSMProxyListDomain | |
| unsigned int | DefaultIndex = 0 |
Protected Attributes inherited from vtkSMDomain | |
| char * | XMLName |
| bool | IsOptional |
| vtkSMDomainInternals * | Internals |
This domain represent a single vtkSMTransferFunctionProxy with a range defined by a vtkSMArrayRangeDomain used internally.
Example usage :
Definition at line 31 of file vtkSMRangedTransferFunctionDomain.h.
Definition at line 35 of file vtkSMRangedTransferFunctionDomain.h.
Reimplemented from vtkSMProxyListDomain.
Return a range min.
value if it exists. If the min. exists exists is set to 1. Otherwise, it is set to 0. An unspecified min. is equivalent to -inf
Return a range max.
value if it exists. If the max. exists exists is set to 1. Otherwise, it is set to 0. An unspecified max. is equivalent to +inf
| bool vtkSMRangedTransferFunctionDomain::GetRangeMinimumExists | ( | unsigned int | idx | ) |
| bool vtkSMRangedTransferFunctionDomain::GetRangeMaximumExists | ( | unsigned int | idx | ) |
Use GetMaximumExists() GetMaximumExists() to make sure that the bound is set.
Definition at line 66 of file vtkSMRangedTransferFunctionDomain.h.
Definition at line 71 of file vtkSMRangedTransferFunctionDomain.h.
overrideprotectedvirtual |
1.8.13 on Sun Dec 14 2025
