vtkSMRegistrationNamesDomain.h
41 #ifndef vtkSMRegistrationNamesDomain_h
42 #define vtkSMRegistrationNamesDomain_h
43
44 #include "vtkRemotingServerManagerModule.h" //needed for exports
45 #include "vtkSMDomain.h"
46 #include <memory> // for std::unique_ptr
47
49 {
50 public:
53  void PrintSelf(ostream& os, vtkIndent indent) override;
54
55  int SetDefaultValues(vtkSMProperty*, bool use_unchecked_values) override;
56
57 protected:
59  ~vtkSMRegistrationNamesDomain() override;
60
61  int ReadXMLAttributes(vtkSMProperty* prop, vtkPVXMLElement* element) override;
62
63 private:
65  void operator=(const vtkSMRegistrationNamesDomain&) = delete;
66
67  class vtkInternals;
68  std::unique_ptr<vtkInternals> Internals;
69 };
70
71 #endif
domain to set default value for a property using proxy registration names
virtual int SetDefaultValues(vtkSMProperty *, bool vtkNotUsed(use_unchecked_values))
Definition: vtkSMDomain.h:91
represents the possible values a property can have
Definition: vtkSMDomain.h:37
virtual int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *elem)
vtkSMDomainInternals * Internals
Definition: vtkSMDomain.h:275
static vtkSMDomain * New()
