Signals | Public Member Functions | Properties | List of all members
pqColorAnnotationsPropertyWidget Class Reference
pqColorAnnotationsPropertyWidget is used to edit the Annotations property on the "PVLookupTable" proxy. More...
#include <pqColorAnnotationsPropertyWidget.h>
Inheritance diagram for pqColorAnnotationsPropertyWidget:
Collaboration diagram for pqColorAnnotationsPropertyWidget:
Signals
void annotationsChanged ()
 Fired when the annotations are changed. More...
void indexedColorsChanged ()
 Fired when the indexed colors are changed. More...
void indexedOpacitiesChanged ()
 Fired when the indexed opacities are changed. More...
void opacityMappingChanged ()
 Fired when the opacity mapping is changed. More...
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqColorAnnotationsPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr)
 ~pqColorAnnotationsPropertyWidget () override
QList< QVariant > annotations () const
 Get/Set the annotations. More...
void setAnnotations (const QList< QVariant > &)
QList< QVariant > indexedColors () const
 Get/Set the indexed colors. More...
void setIndexedColors (const QList< QVariant > &)
QList< QVariant > indexedOpacities () const
 Get/Set the indexed opacities. More...
void setIndexedOpacities (const QList< QVariant > &)
QVariant opacityMapping () const
 Get/Set the opacity mapping status. More...
void setOpacityMapping (const QVariant &)
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
The property group can comprise of two properties, Annotations and IndexedColors.
Definition at line 18 of file pqColorAnnotationsPropertyWidget.h.
◆ pqColorAnnotationsPropertyWidget()
pqColorAnnotationsPropertyWidget::pqColorAnnotationsPropertyWidget ( vtkSMProxy proxy,
vtkSMPropertyGroup smgroup,
QWidget *  parent = nullptr
◆ ~pqColorAnnotationsPropertyWidget()
pqColorAnnotationsPropertyWidget::~pqColorAnnotationsPropertyWidget ( )
override
◆ annotations()
QList<QVariant> pqColorAnnotationsPropertyWidget::annotations ( ) const
This is a list generated by flattening 2-tuples where 1st value is the annotated value and second is the annotation text.
◆ setAnnotations()
void pqColorAnnotationsPropertyWidget::setAnnotations ( const QList< QVariant > &  )
◆ indexedColors()
QList<QVariant> pqColorAnnotationsPropertyWidget::indexedColors ( ) const
This is a list generated by flattening 3-tuples (r,g,b).
◆ setIndexedColors()
void pqColorAnnotationsPropertyWidget::setIndexedColors ( const QList< QVariant > &  )
◆ indexedOpacities()
QList<QVariant> pqColorAnnotationsPropertyWidget::indexedOpacities ( ) const
◆ setIndexedOpacities()
void pqColorAnnotationsPropertyWidget::setIndexedOpacities ( const QList< QVariant > &  )
◆ opacityMapping()
QVariant pqColorAnnotationsPropertyWidget::opacityMapping ( ) const
◆ setOpacityMapping()
void pqColorAnnotationsPropertyWidget::setOpacityMapping ( const QVariant &  )
◆ annotationsChanged
void pqColorAnnotationsPropertyWidget::annotationsChanged ( )
signal
◆ indexedColorsChanged
void pqColorAnnotationsPropertyWidget::indexedColorsChanged ( )
signal
◆ indexedOpacitiesChanged
void pqColorAnnotationsPropertyWidget::indexedOpacitiesChanged ( )
signal
◆ opacityMappingChanged
void pqColorAnnotationsPropertyWidget::opacityMappingChanged ( )
signal
Property Documentation
◆ annotations
readwrite
Definition at line 20 of file pqColorAnnotationsPropertyWidget.h.
◆ indexedColors
readwrite
Definition at line 21 of file pqColorAnnotationsPropertyWidget.h.
◆ indexedOpacities
readwrite
Definition at line 22 of file pqColorAnnotationsPropertyWidget.h.
◆ opacityMapping
readwrite
Definition at line 23 of file pqColorAnnotationsPropertyWidget.h.
