Public Member Functions | Static Public Member Functions | List of all members
pqComparativeXYBarChartView Class Reference
The comparative bar chart subclass. More...
#include <pqComparativeXYBarChartView.h>
Inheritance diagram for pqComparativeXYBarChartView:
Collaboration diagram for pqComparativeXYBarChartView:
 pqComparativeXYBarChartView (const QString &group, const QString &name, vtkSMComparativeViewProxy *view, pqServer *server, QObject *parent=nullptr)
 ~pqComparativeXYBarChartView () override
- Public Member Functions inherited from pqComparativeContextView
 ~pqComparativeContextView () override
vtkContextViewgetVTKContextView () const override
vtkSMContextViewProxygetContextViewProxy () const override
 Returns the context view proxy associated with this object. More...
vtkSMComparativeViewProxygetComparativeViewProxy () const
virtual vtkSMViewProxygetViewProxy () const
 Returns the proxy of the root plot view in the comparative view. More...
- Public Member Functions inherited from pqContextView
 ~pqContextView () override
virtual bool supportsSelection () const
 Returns true if selection can be done. More...
bool supportsCapture () const override
 Returns if this view module can support image capture. More...
virtual void setSelectionAction (int selAction)
 set/get the selection action in the context view, defined by vtkChart enumeration from SELECT to SELECT_POLYGON. More...
virtual int selectionAction ()
void resetDisplay (bool closest=false) override
 Resets the zoom level to 100%. More...
- Public Member Functions inherited from pqView
 ~pqView () override
 Returns the internal render Module proxy associated with this object. More...
virtual vtkViewgetClientSideView () const
 Return the client-side vtkView encapsulated by this view (if any), or return nullptr. More...
QWidget * widget ()
 Return a widget associated with this view. More...
virtual bool supportsUndo () const
 Returns if this view module can support undo/redo. More...
QString getViewType () const
 Returns the type of this view module. More...
virtual bool canUndo () const
 Returns true if undo can be done. More...
virtual bool canRedo () const
 Returns true if redo can be done. More...
virtual QSize getSize ()
 Returns the current size of the rendering context. More...
bool hasRepresentation (pqRepresentation *repr) const
 This method checks if the representation is shown in this view. More...
int getNumberOfRepresentations () const
 Returns the number representations in the view. More...
int getNumberOfVisibleRepresentations () const
int getNumberOfVisibleDataRepresentations () const
pqRepresentationgetRepresentation (int index) const
 Returns the representation for the specified index where (index < getNumberOfRepresentations()). More...
QList< pqRepresentation * > getRepresentations () const
 Returns a list of representations in this view. More...
bool canDisplay (pqOutputPort *opPort) const
 This method returns is any pqPipelineSource can be displayed in this view. More...
- Public Member Functions inherited from pqProxy
 pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqProxy () override
pqServergetServer () const
 Get the server on which this proxy exists. More...
void rename (const QString &newname)
 This is a convenience method. More...
const QString & getSMName ()
 Get the name with which this proxy is registered on the server manager. More...
const QString & getSMGroup ()
vtkSMProxygetProxy () const
 Get the vtkSMProxy this object stands for. More...
ModifiedState modifiedState () const
 Gets whether or not the source has been modified. More...
void setModifiedState (ModifiedState modified)
 Sets whether or not the source has been modified. More...
vtkPVXMLElementgetHints () const
 Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > getHelperProxies () const
 Returns a list of all helper proxies. More...
QList< vtkSMProxy * > getHelperProxies (const QString &key) const
 Returns a list of all the helper proxies added with a given key. More...
QList< QString > getHelperKeys () const
 Returns the keys for helper proxies. More...
virtual void addHelperProxy (const QString &key, vtkSMProxy *)
 Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void removeHelperProxy (const QString &key, vtkSMProxy *)
void updateHelperProxies () const
 Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManagerproxyManager () const
 Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool userModifiedSMName ()
 Return whether or not the user has modified the GUI name of the source. More...
- Public Member Functions inherited from pqServerManagerModelItem
 pqServerManagerModelItem (QObject *parent=nullptr)
 ~pqServerManagerModelItem () override
static QString chartViewType ()
static QString chartViewTypeName ()
- Static Public Member Functions inherited from pqProxy
static pqProxyfindProxyWithHelper (vtkSMProxy *aproxy, QString &key)
 Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
static std::string rstToHtml (const char *rstStr)
 convert proxy documentation from RST to HTML (so that it can be used in Qt) More...
static QString rstToHtml (const QString &rstStr)
- Public Types inherited from pqView
enum  SelectionModifier { PV_SELECTION_DEFAULT = 0, PV_SELECTION_ADDITION, PV_SELECTION_SUBTRACTION, PV_SELECTION_TOGGLE }
- Public Types inherited from pqProxy
enum  ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED }
 The modification state of this proxy. More...
- Public Slots inherited from pqView
virtual void render ()
 Request a StillRender on idle. More...
virtual void forceRender ()
 Forces an immediate render. More...
void cancelPendingRenders ()
 Cancels any pending renders. More...
virtual void undo ()
 Called to undo interaction. More...
virtual void redo ()
 Called to redo interaction. More...
- Signals inherited from pqView
void updateDataEvent ()
 Fired when the vtkSMViewProxy fires the vtkCommand::UpdateDataEvent The view proxy fires this event at the end of vtkSMViewProxy::Update() when the update executes, not just when the method is called. More...
void representationAdded (pqRepresentation *)
 Fired after a representation has been added to this view. More...
void representationRemoved (pqRepresentation *)
 Fired after a representation has been removed from this view. More...
void beginRender ()
 Fired when the render module fires a vtkCommand::StartEvent signalling the beginning of rendering. More...
void endRender ()
 Fired when the render module fires a vtkCommand::EndEvent signalling the end of rendering. More...
void representationVisibilityChanged (pqRepresentation *repr, bool visible)
 Fired when any representation visibility changes. More...
void canUndoChanged (bool)
 Fired when interaction undo stack status changes. More...
void canRedoChanged (bool)
void selected (pqOutputPort *opport)
 Fired when a selection is made in this view. More...
void picked (pqOutputPort *opport)
 Fired when a port is picked. More...
void beginProgress ()
 Fired before doing any actions that may result in progress events that must be reported by the client. More...
void endProgress ()
 Fired after performing any actions that may result in progress events. More...
void progress (const QString &message, int percent_progress)
 Fired to notify the current execution progress. More...
void multipleSelected (QList< pqOutputPort *> opports)
 Fired when UseMultipleRepresentationSelection is set to on and selection on multiple representations is made in this view. More...
- Signals inherited from pqProxy
void nameChanged (pqServerManagerModelItem *)
 Fired when the name of the proxy is changed. More...
void modifiedStateChanged (pqServerManagerModelItem *)
 Fired when the modified status changes for the proxy. More...
- Protected Slots inherited from pqComparativeContextView
void updateViewWidgets ()
 Called when the layout on the comparative vis changes. More...
- Protected Slots inherited from pqContextView
void startInteraction ()
 Slots called when vtkCommand::StartInteractionEvent and vtkCommand::EndInteractionEvent are fired by vtkSMContextViewProxy. More...
void endInteraction ()
- Protected Slots inherited from pqProxy
void onProxyRegistered (const QString &, const QString &, vtkSMProxy *)
void onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *)
- Protected Member Functions inherited from pqComparativeContextView
QWidget * createWidget () override
 Create the QWidget for this view. More...
 pqComparativeContextView (const QString &type, const QString &group, const QString &name, vtkSMComparativeViewProxy *view, pqServer *server, QObject *parent=nullptr)
 Constructor: type :- view type. More...
- Protected Member Functions inherited from pqContextView
 pqContextView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr)
 Creates a new instance of the QWidget subclass to be used to show this view. More...
virtual void selectionChanged ()
 Listen for new selection events, and pass them back to ParaView. More...
virtual void setSelection (vtkSelection *)
 Set selection to the view. More...
- Protected Member Functions inherited from pqView
 pqView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr)
void initialize () override
 Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
- Protected Member Functions inherited from pqProxy
void setSMName (const QString &new_name)
 Make this pqProxy take on a new identity. More...
virtual void addInternalHelperProxy (const QString &key, vtkSMProxy *) const
virtual void removeInternalHelperProxy (const QString &key, vtkSMProxy *) const
- Protected Member Functions inherited from pqServerManagerModelItem
vtkEventQtSlotConnectgetConnector ()
 All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
- Protected Attributes inherited from pqComparativeContextView
QPointer< QWidget > Widget
- Protected Attributes inherited from pqContextView
command * Command
Definition at line 12 of file pqComparativeXYBarChartView.h.
◆ pqComparativeXYBarChartView()
pqComparativeXYBarChartView::pqComparativeXYBarChartView ( const QString &  group,
const QString &  name,
vtkSMComparativeViewProxy view,
pqServer server,
QObject *  parent = nullptr
◆ ~pqComparativeXYBarChartView()
pqComparativeXYBarChartView::~pqComparativeXYBarChartView ( )
override
◆ chartViewType()
static QString pqComparativeXYBarChartView::chartViewType ( )
inlinestatic
Definition at line 22 of file pqComparativeXYBarChartView.h.
◆ chartViewTypeName()
static QString pqComparativeXYBarChartView::chartViewTypeName ( )
inlinestatic
Definition at line 23 of file pqComparativeXYBarChartView.h.
