#include <pqDoubleVectorPropertyWidget.h>
virtual void | setView (pqView *) |
| called to set the active view. More...
template<class T > |
static QString | getXMLName (T *object) |
| Description: This static utility method returns the XML name for an object as a QString. More...
static QString | getTooltip (vtkSMProperty *property) |
| Returns the tooltip to use for the property. More...
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
| Helper method to return value from WidgetHeight XML hint, if any. More...
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
| Parse a XML element as a list of label to use for this widget. More...
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
| For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More...
void | addDecorator (pqPropertyWidgetDecorator *) |
| Register a decorator. More...
void | removeDecorator (pqPropertyWidgetDecorator *) |
| Unregisters a decorator. More...
pqPropertyLinks & | links () |
| Provides access to the pqPropertyLinks instance. More...
◆ pqDoubleVectorPropertyWidget()
pqDoubleVectorPropertyWidget::pqDoubleVectorPropertyWidget |
vtkSMProperty * |
property, |
vtkSMProxy * |
proxy, |
QWidget * |
parent = nullptr |
◆ ~pqDoubleVectorPropertyWidget()
pqDoubleVectorPropertyWidget::~pqDoubleVectorPropertyWidget |
◆ apply()
void pqDoubleVectorPropertyWidget::apply |
◆ reset()
void pqDoubleVectorPropertyWidget::reset |
◆ clearHighlight
void pqDoubleVectorPropertyWidget::clearHighlight |
signal |
◆ highlightResetButton
void pqDoubleVectorPropertyWidget::highlightResetButton |
signal |
◆ resetButtonClicked
virtual void pqDoubleVectorPropertyWidget::resetButtonClicked |
protectedvirtualslot |
called when the user clicks the "reset" button for a specific property.
◆ scaleHalf
void pqDoubleVectorPropertyWidget::scaleHalf |
protectedslot |
◆ scaleTwice
void pqDoubleVectorPropertyWidget::scaleTwice |
protectedslot |
◆ scale
void pqDoubleVectorPropertyWidget::scale |
double |
protectedslot |
◆ resetToActiveDataBounds
void pqDoubleVectorPropertyWidget::resetToActiveDataBounds |
protectedslot |
sets the value using active source's data bounds.
◆ resetToBounds
void pqDoubleVectorPropertyWidget::resetToBounds |
const double |
bds[6] | ) |
protectedslot |
sets the value to the specified bounds.
