pqIndexSelectionWidget displays a list of labels and slider widgets, intended to be used for selecting an index into a zero-based enumeration.
#include <pqIndexSelectionWidget.h>
bool | eventFilter (QObject *obj, QEvent *e) override |
void | propertyChanged () |
| Update the widget state from the PropertyLink Qt property. More...
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
| For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More...
void | addDecorator (pqPropertyWidgetDecorator *) |
| Register a decorator. More...
void | removeDecorator (pqPropertyWidgetDecorator *) |
| Unregisters a decorator. More...
pqPropertyLinks & | links () |
| Provides access to the pqPropertyLinks instance. More...
Definition at line 22 of file pqIndexSelectionWidget.h.
◆ pqIndexSelectionWidget()
pqIndexSelectionWidget::pqIndexSelectionWidget |
vtkSMProxy * |
proxy, |
vtkSMProperty * |
property, |
QWidget * |
parent = nullptr |
◆ ~pqIndexSelectionWidget()
pqIndexSelectionWidget::~pqIndexSelectionWidget |
◆ setHeaderLabel
void pqIndexSelectionWidget::setHeaderLabel |
const QString & |
str | ) |
slot |
◆ setPushPropertyName
void pqIndexSelectionWidget::setPushPropertyName |
const QByteArray & |
pName | ) |
slot |
◆ widgetModified
void pqIndexSelectionWidget::widgetModified |
signal |
◆ currentChanged [1/3]
void pqIndexSelectionWidget::currentChanged |
const QString & |
current | ) |
protectedslot |
◆ currentChanged [2/3]
int |
current | ) |
protectedslot |
◆ currentChanged [3/3]
protectedslot |
◆ updateProperty
void pqIndexSelectionWidget::updateProperty |
protectedslot |
Start a timer that calls updatePropertyImpl.
This slot is triggered when a widget is modified.
◆ updatePropertyImpl
void pqIndexSelectionWidget::updatePropertyImpl |
protectedslot |
Update the Qt property with current widget state.
Emits widgetModified.
◆ eventFilter()
bool pqIndexSelectionWidget::eventFilter |
QObject * |
obj, |
QEvent * |
e |
◆ propertyChanged()
void pqIndexSelectionWidget::propertyChanged |
