Public Member Functions | Static Public Member Functions | List of all members
pqIntVectorPropertyWidget Class Reference
#include <pqIntVectorPropertyWidget.h>
Inheritance diagram for pqIntVectorPropertyWidget:
Collaboration diagram for pqIntVectorPropertyWidget:
 pqIntVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
 ~pqIntVectorPropertyWidget () override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
static pqPropertyWidgetcreateWidget (vtkSMIntVectorProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent)
 Creates known pqPropertyWidget subclasses for vtkSMIntVectorProperty property. More...
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void changeAvailable ()
void changeFinished ()
void restartRequired ()
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
Definition at line 12 of file pqIntVectorPropertyWidget.h.
◆ pqIntVectorPropertyWidget()
pqIntVectorPropertyWidget::pqIntVectorPropertyWidget ( vtkSMProperty property,
vtkSMProxy proxy,
QWidget *  parent = nullptr
◆ ~pqIntVectorPropertyWidget()
pqIntVectorPropertyWidget::~pqIntVectorPropertyWidget ( )
override
◆ createWidget()
static pqPropertyWidget* pqIntVectorPropertyWidget::createWidget ( vtkSMIntVectorProperty smproperty,
vtkSMProxy smproxy,
QWidget *  parent
