Public Slots | Signals | Public Member Functions | Properties | List of all members
pqLanguageChooserWidget Class Reference
pqLanguageChooserWidget is a property widget that shows a combo-box with values equal to the currently available translation languages. More...
#include <pqLanguageChooserWidget.h>
Inheritance diagram for pqLanguageChooserWidget:
Collaboration diagram for pqLanguageChooserWidget:
Public Slots
void setValue (QString &value)
 set the default value for the widget among the current items. More...
Signals
void valueChanged ()
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqLanguageChooserWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr)
 ~pqLanguageChooserWidget () override
QString value () const
 get the current selected locale. More...
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Properties
QString value
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
Definition at line 17 of file pqLanguageChooserWidget.h.
◆ pqLanguageChooserWidget()
pqLanguageChooserWidget::pqLanguageChooserWidget ( vtkSMProxy proxy,
vtkSMProperty smproperty,
QWidget *  parent = nullptr
◆ ~pqLanguageChooserWidget()
pqLanguageChooserWidget::~pqLanguageChooserWidget ( )
override
◆ value()
QString pqLanguageChooserWidget::value ( ) const
◆ setValue
void pqLanguageChooserWidget::setValue ( QString &  value)
slot
If the value is not in the items, add it, make it default and re-sort the list alphabetically.
◆ valueChanged
void pqLanguageChooserWidget::valueChanged ( )
signal
Property Documentation
◆ value
readwrite
Definition at line 21 of file pqLanguageChooserWidget.h.
