Property widget that can be used to edit a proxy set as the value of a ProxyProperty in a pop-up dialog. More...
#include <pqProxyEditorPropertyWidget.h>
Public Slots | |
void | setProxyToEdit (pqSMProxy) |
virtual void | setView (pqView *) |
called to set the active view. More... | |
Signals | |
void | dummySignal () |
void | viewChanged (pqView *view) |
This signal is emitted when the current view changes. More... | |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
pqProxyEditorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
~pqProxyEditorPropertyWidget () override | |
pqSMProxy | proxyToEdit () const |
pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqPropertyWidget () override | |
virtual void | apply () |
virtual void | reset () |
virtual void | updateWidget (bool showing_advanced_properties) |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual char * | panelVisibility () const |
Forward calls to vtkSMProperty. More... | |
virtual void | setPanelVisibility (const char *vis) |
virtual bool | isSingleRowItem () const |
Determines if the PropertyWidget must be constructed using a single row. More... | |
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
Provides access to the decorators for this widget. More... | |
void | setProperty (vtkSMProperty *property) |
virtual void | select () |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More... | |
virtual void | selectPort (int portIndex) |
virtual void | deselect () |
bool | isSelected () const |
Protected Slots | |
void | buttonClicked () |
Properties | |
pqSMProxy | proxyToEdit |
template<class T > | |
static QString | getXMLName (T *object) |
Description: This static utility method returns the XML name for an object as a QString. More... | |
static QString | getTooltip (vtkSMProperty *property) |
Returns the tooltip to use for the property. More... | |
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
Helper method to return value from WidgetHeight XML hint, if any. More... | |
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
Parse a XML element as a list of label to use for this widget. More... | |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More... | |
void | addDecorator (pqPropertyWidgetDecorator *) |
Register a decorator. More... | |
void | removeDecorator (pqPropertyWidgetDecorator *) |
Unregisters a decorator. More... | |
pqPropertyLinks & | links () |
Provides access to the pqPropertyLinks instance. More... | |
e.g. RenderView proxy has a "GridActor3D" ProxyProperty which is set to a "GridActor3D" proxy. Using this widget allows the users to edit the properties on this GridActor3D, when present.
To use this widget, add 'panel_widget="proxy_editor"' to the property's XML.
Since it's common to have a property on the proxy being edited in the popup dialog which controls its visibility (or enabled state), we add support for putting that property as a checkbox in this pqProxyEditorPropertyWidget itself. For that, one can use ProxyEditorPropertyWidget
hints.
Example XML:
Definition at line 40 of file pqProxyEditorPropertyWidget.h.
pqProxyEditorPropertyWidget::pqProxyEditorPropertyWidget | ( | vtkSMProxy * | proxy, |
vtkSMProperty * | smproperty, | ||
QWidget * | parent = nullptr |
pqSMProxy pqProxyEditorPropertyWidget::proxyToEdit | ( | ) | const |
slot |
protectedslot |
signal |
readwrite |
Definition at line 44 of file pqProxyEditorPropertyWidget.h.
