Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqRenderViewBase Class Referenceabstract
pqRenderViewBase is an abstract base class for all render-view based views. More...
#include <pqRenderViewBase.h>
Inheritance diagram for pqRenderViewBase:
Collaboration diagram for pqRenderViewBase:
 ~pqRenderViewBase () override
virtual void resetCamera (bool closest=false, double offsetRatio=0.9)=0
 Resets the camera to include all visible data. More...
void resetDisplay (bool closest=false) override
 Called to reset the view's display. More...
- Public Member Functions inherited from pqView
 ~pqView () override
vtkSMViewProxygetViewProxy () const
 Returns the internal render Module proxy associated with this object. More...
virtual vtkViewgetClientSideView () const
 Return the client-side vtkView encapsulated by this view (if any), or return nullptr. More...
QWidget * widget ()
 Return a widget associated with this view. More...
virtual bool supportsUndo () const
 Returns if this view module can support undo/redo. More...
virtual bool supportsCapture () const
 Returns if this view module can support image capture. More...
QString getViewType () const
 Returns the type of this view module. More...
virtual bool canUndo () const
 Returns true if undo can be done. More...
virtual bool canRedo () const
 Returns true if redo can be done. More...
virtual QSize getSize ()
 Returns the current size of the rendering context. More...
bool hasRepresentation (pqRepresentation *repr) const
 This method checks if the representation is shown in this view. More...
int getNumberOfRepresentations () const
 Returns the number representations in the view. More...
int getNumberOfVisibleRepresentations () const
int getNumberOfVisibleDataRepresentations () const
pqRepresentationgetRepresentation (int index) const
 Returns the representation for the specified index where (index < getNumberOfRepresentations()). More...
QList< pqRepresentation * > getRepresentations () const
 Returns a list of representations in this view. More...
bool canDisplay (pqOutputPort *opPort) const
 This method returns is any pqPipelineSource can be displayed in this view. More...
- Public Member Functions inherited from pqProxy
 pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqProxy () override
pqServergetServer () const
 Get the server on which this proxy exists. More...
void rename (const QString &newname)
 This is a convenience method. More...
const QString & getSMName ()
 Get the name with which this proxy is registered on the server manager. More...
const QString & getSMGroup ()
vtkSMProxygetProxy () const
 Get the vtkSMProxy this object stands for. More...
ModifiedState modifiedState () const
 Gets whether or not the source has been modified. More...
void setModifiedState (ModifiedState modified)
 Sets whether or not the source has been modified. More...
vtkPVXMLElementgetHints () const
 Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > getHelperProxies () const
 Returns a list of all helper proxies. More...
QList< vtkSMProxy * > getHelperProxies (const QString &key) const
 Returns a list of all the helper proxies added with a given key. More...
QList< QString > getHelperKeys () const
 Returns the keys for helper proxies. More...
virtual void addHelperProxy (const QString &key, vtkSMProxy *)
 Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void removeHelperProxy (const QString &key, vtkSMProxy *)
void updateHelperProxies () const
 Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManagerproxyManager () const
 Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool userModifiedSMName ()
 Return whether or not the user has modified the GUI name of the source. More...
- Public Member Functions inherited from pqServerManagerModelItem
 pqServerManagerModelItem (QObject *parent=nullptr)
 ~pqServerManagerModelItem () override
Protected Slots
virtual void initializeAfterObjectsCreated ()
void beginDelayInteractiveRender ()
 Triggered by DelayNonInteractiveRenderEvent. More...
void endDelayInteractiveRender ()
void updateStatusMessage ()
 Triggered by internal timer to update the status bar message. More...
- Protected Slots inherited from pqProxy
void onProxyRegistered (const QString &, const QString &, vtkSMProxy *)
void onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *)
 pqRenderViewBase (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr)
bool eventFilter (QObject *caller, QEvent *e) override
 Overridden to popup the context menu, if some actions have been added using addMenuAction. More...
QWidget * createWidget () override
 Creates a new instance of the QWidget subclass to be used to show this view. More...
void initialize () override
 Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
- Protected Member Functions inherited from pqView
 pqView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr)
 Constructor: type :- view type. More...
- Protected Member Functions inherited from pqProxy
void setSMName (const QString &new_name)
 Make this pqProxy take on a new identity. More...
virtual void addInternalHelperProxy (const QString &key, vtkSMProxy *) const
virtual void removeInternalHelperProxy (const QString &key, vtkSMProxy *) const
- Protected Member Functions inherited from pqServerManagerModelItem
vtkEventQtSlotConnectgetConnector ()
 All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
- Public Types inherited from pqView
enum  SelectionModifier { PV_SELECTION_DEFAULT = 0, PV_SELECTION_ADDITION, PV_SELECTION_SUBTRACTION, PV_SELECTION_TOGGLE }
- Public Types inherited from pqProxy
enum  ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED }
 The modification state of this proxy. More...
- Public Slots inherited from pqView
virtual void render ()
 Request a StillRender on idle. More...
virtual void forceRender ()
 Forces an immediate render. More...
void cancelPendingRenders ()
 Cancels any pending renders. More...
virtual void undo ()
 Called to undo interaction. More...
virtual void redo ()
 Called to redo interaction. More...
- Signals inherited from pqView
void updateDataEvent ()
 Fired when the vtkSMViewProxy fires the vtkCommand::UpdateDataEvent The view proxy fires this event at the end of vtkSMViewProxy::Update() when the update executes, not just when the method is called. More...
void representationAdded (pqRepresentation *)
 Fired after a representation has been added to this view. More...
void representationRemoved (pqRepresentation *)
 Fired after a representation has been removed from this view. More...
void beginRender ()
 Fired when the render module fires a vtkCommand::StartEvent signalling the beginning of rendering. More...
void endRender ()
 Fired when the render module fires a vtkCommand::EndEvent signalling the end of rendering. More...
void representationVisibilityChanged (pqRepresentation *repr, bool visible)
 Fired when any representation visibility changes. More...
void canUndoChanged (bool)
 Fired when interaction undo stack status changes. More...
void canRedoChanged (bool)
void selected (pqOutputPort *opport)
 Fired when a selection is made in this view. More...
void picked (pqOutputPort *opport)
 Fired when a port is picked. More...
void beginProgress ()
 Fired before doing any actions that may result in progress events that must be reported by the client. More...
void endProgress ()
 Fired after performing any actions that may result in progress events. More...
void progress (const QString &message, int percent_progress)
 Fired to notify the current execution progress. More...
void multipleSelected (QList< pqOutputPort *> opports)
 Fired when UseMultipleRepresentationSelection is set to on and selection on multiple representations is made in this view. More...
- Signals inherited from pqProxy
void nameChanged (pqServerManagerModelItem *)
 Fired when the name of the proxy is changed. More...
void modifiedStateChanged (pqServerManagerModelItem *)
 Fired when the modified status changes for the proxy. More...
- Static Public Member Functions inherited from pqProxy
static pqProxyfindProxyWithHelper (vtkSMProxy *aproxy, QString &key)
 Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
static std::string rstToHtml (const char *rstStr)
 convert proxy documentation from RST to HTML (so that it can be used in Qt) More...
static QString rstToHtml (const QString &rstStr)
It encapuslates some of the commonly needed functionality for all such views.
Definition at line 16 of file pqRenderViewBase.h.
◆ pqRenderViewBase()
pqRenderViewBase::pqRenderViewBase ( const QString &  type,
const QString &  group,
const QString &  name,
vtkSMViewProxy renModule,
pqServer server,
QObject *  parent = nullptr
◆ ~pqRenderViewBase()
pqRenderViewBase::~pqRenderViewBase ( )
override
◆ resetCamera()
virtual void pqRenderViewBase::resetCamera ( bool  closest = false,
double  offsetRatio = 0.9
pure virtual
It is essential to call this resetCamera, to ensure that the reset camera action gets pushed on the interaction undo stack.
OffsetRatio can be used to add a zoom offset (only applicable when closest is true).
Implemented in pqRenderView.
◆ resetDisplay()
void pqRenderViewBase::resetDisplay ( bool  closest = false)
This method calls resetCamera().
Reimplemented from pqView.
◆ initializeAfterObjectsCreated
virtual void pqRenderViewBase::initializeAfterObjectsCreated ( )
protectedvirtualslot
◆ beginDelayInteractiveRender
void pqRenderViewBase::beginDelayInteractiveRender ( )
protectedslot
◆ endDelayInteractiveRender
void pqRenderViewBase::endDelayInteractiveRender ( )
protectedslot
◆ updateStatusMessage
void pqRenderViewBase::updateStatusMessage ( )
protectedslot
◆ eventFilter()
bool pqRenderViewBase::eventFilter ( QObject *  caller,
QEvent *  e
◆ createWidget()
QWidget* pqRenderViewBase::createWidget ( )
overrideprotectedvirtual
Default implementation creates a pqQVTKWidget.
Implements pqView.
◆ initialize()
void pqRenderViewBase::initialize ( )
This needs to be done only once, after the object has been created.
Reimplemented from pqProxy.
