pqScalarsToColors is a represents a vtkScalarsToColors proxy. More...
#include <pqScalarsToColors.h>
enum | Mode { MAGNITUDE = 0, COMPONENT = 1 } |
enum | RangeScalingModes { GROW_ON_MODIFIED, GROW_ON_UPDATED } |
enum | ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED } |
The modification state of this proxy. More... | |
Public Slots | |
void | hideUnusedScalarBars () |
void | setScalarRangeLock (bool lock) |
Set the scalar range lock. More... | |
void | build () |
Triggers a build on the lookup table. More... | |
Signals | |
void | componentOrModeChanged () |
signal fired when the "VectorMode" or "VectorComponent" properties are modified. More... | |
void | nameChanged (pqServerManagerModelItem *) |
Fired when the name of the proxy is changed. More... | |
void | modifiedStateChanged (pqServerManagerModelItem *) |
Fired when the modified status changes for the proxy. More... | |
pqScalarsToColors (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
~pqScalarsToColors () override | |
pqScalarBarRepresentation * | getScalarBar (pqRenderViewBase *ren) const |
Returns the first scalar bar visible in the given render module, if any. More... | |
bool | getScalarRangeLock () const |
Returns if the lookup table's scalar range is locked. More... | |
void | setScalarRange (double min, double max) |
Sets the scalar range. More... | |
QPair< double, double > | getScalarRange () const |
Returns the current scalar range. More... | |
bool | getUseLogScale () const |
Returns true if a log scale is being used. More... | |
void | setVectorMode (Mode mode, int component) |
Mode | getVectorMode () const |
int | getVectorComponent () const |
void | updateScalarBarTitles (const QString &component) |
Convenience method to update the titles for all color legends showing this lookup table. More... | |
pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
~pqProxy () override | |
pqServer * | getServer () const |
Get the server on which this proxy exists. More... | |
void | rename (const QString &newname) |
This is a convenience method. More... | |
const QString & | getSMName () |
Get the name with which this proxy is registered on the server manager. More... | |
const QString & | getSMGroup () |
vtkSMProxy * | getProxy () const |
Get the vtkSMProxy this object stands for. More... | |
ModifiedState | modifiedState () const |
Gets whether or not the source has been modified. More... | |
void | setModifiedState (ModifiedState modified) |
Sets whether or not the source has been modified. More... | |
vtkPVXMLElement * | getHints () const |
Returns the hints for this proxy, if any. More... | |
QList< vtkSMProxy * > | getHelperProxies () const |
Returns a list of all helper proxies. More... | |
QList< vtkSMProxy * > | getHelperProxies (const QString &key) const |
Returns a list of all the helper proxies added with a given key. More... | |
QList< QString > | getHelperKeys () const |
Returns the keys for helper proxies. More... | |
virtual void | addHelperProxy (const QString &key, vtkSMProxy *) |
Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More... | |
void | removeHelperProxy (const QString &key, vtkSMProxy *) |
void | updateHelperProxies () const |
Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More... | |
vtkSMSessionProxyManager * | proxyManager () const |
Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More... | |
bool | userModifiedSMName () |
Return whether or not the user has modified the GUI name of the source. More... | |
pqServerManagerModelItem (QObject *parent=nullptr) | |
~pqServerManagerModelItem () override | |
static void | setColorRangeScalingMode (int) |
This merely update the application settings with correct values for the temporal range scaling mode. More... | |
static int | colorRangeScalingMode (int default_value=GROW_ON_MODIFIED) |
static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More... | |
static std::string | rstToHtml (const char *rstStr) |
convert proxy documentation from RST to HTML (so that it can be used in Qt) More... | |
static QString | rstToHtml (const QString &rstStr) |
Protected Slots | |
void | checkRange () |
Checks to make sure that the range is compatible with the log flag and adjusts it if necessary. More... | |
void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
void | setSMName (const QString &new_name) |
Make this pqProxy take on a new identity. More... | |
virtual void | initialize () |
virtual void | addInternalHelperProxy (const QString &key, vtkSMProxy *) const |
virtual void | removeInternalHelperProxy (const QString &key, vtkSMProxy *) const |
vtkEventQtSlotConnect * | getConnector () |
All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More... | |
Definition at line 19 of file pqScalarsToColors.h.
Enumerator | |
MAGNITUDE | |
COMPONENT |
Definition at line 55 of file pqScalarsToColors.h.
Enumerator | |
GROW_ON_MODIFIED | |
GROW_ON_UPDATED |
Definition at line 77 of file pqScalarsToColors.h.
pqScalarsToColors::pqScalarsToColors | ( | const QString & | group, |
const QString & | name, | ||
vtkSMProxy * | proxy, | ||
pqServer * | server, | ||
QObject * | parent = nullptr |
pqScalarBarRepresentation* pqScalarsToColors::getScalarBar | ( | pqRenderViewBase * | ren | ) | const |
bool pqScalarsToColors::getScalarRangeLock | ( | ) | const |
Does not consider the ScalarRangeLock. Moves all control points uniformly to fit the new range.
If number of RGBPoints is 0, then the scalar range is not defined (in which case this method returns (0, 0).
bool pqScalarsToColors::getUseLogScale | ( | ) | const |
Mode pqScalarsToColors::getVectorMode | ( | ) | const |
int pqScalarsToColors::getVectorComponent | ( | ) | const |
void pqScalarsToColors::updateScalarBarTitles | ( | const QString & | component | ) |
This only updates the component part of the title.
Components that scale scalar range should look at this setting to determine how the scaling should be done. This provides access to the application settings that controls when color table ranges are updated by the application. Components that scale scalar range should look at this setting to determine how the scaling should be done.
signal |
slot |
slot |
slot |
protectedslot |
