pqSeriesEditorPropertyWidget is the pqPropertyWidget used to edit plot-options for a xy-series. More...
#include <pqSeriesEditorPropertyWidget.h>
Signals | |
void | presetLabelChanged () |
void | presetColorChanged () |
void | seriesVisibilityChanged () |
Fired when the series visibility changes. More... | |
void | seriesLabelChanged () |
Fired when the series labels change. More... | |
void | seriesColorChanged () |
Fired when the series colors change. More... | |
void | seriesOpacityChanged () |
Fired when the series opacity changes. More... | |
void | seriesLineThicknessChanged () |
Fired when the series line thickness changes. More... | |
void | seriesLineStyleChanged () |
Fired when the series line style changes. More... | |
void | seriesMarkerStyleChanged () |
Fired when the series marker style changes. More... | |
void | seriesMarkerSizeChanged () |
Fired when the series marker size changes. More... | |
void | seriesPlotCornerChanged () |
Fired when the series plot corners change. More... | |
void | viewChanged (pqView *view) |
This signal is emitted when the current view changes. More... | |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
pqSeriesEditorPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
~pqSeriesEditorPropertyWidget () override | |
QList< QVariant > | presetColor () const |
void | setPresetColor (const QList< QVariant > &) |
QList< QVariant > | presetLabel () const |
void | setPresetLabel (const QList< QVariant > &) |
QList< QVariant > | seriesVisibility () const |
Get/Set the visibility for series. More... | |
void | setSeriesVisibility (const QList< QVariant > &) |
QList< QVariant > | seriesColor () const |
Get/Set the color for each of the series. More... | |
void | setSeriesColor (const QList< QVariant > &) |
QList< QVariant > | seriesOpacity () const |
Get/Set the opacity for each of the series. More... | |
void | setSeriesOpacity (const QList< QVariant > &) |
QList< QVariant > | seriesLabel () const |
Get/Set the label for each of the series. More... | |
void | setSeriesLabel (const QList< QVariant > &) |
QList< QVariant > | seriesLineThickness () const |
Get/Set the line-thickness for each of the series. More... | |
void | setSeriesLineThickness (const QList< QVariant > &) |
QList< QVariant > | seriesLineStyle () const |
Get/Set the line-style for each of the series. More... | |
void | setSeriesLineStyle (const QList< QVariant > &) |
QList< QVariant > | seriesMarkerStyle () const |
Get/Set the marker-style for each of the series. More... | |
void | setSeriesMarkerStyle (const QList< QVariant > &) |
QList< QVariant > | seriesMarkerSize () const |
Get/Set the marker-size for each of the series. More... | |
void | setSeriesMarkerSize (const QList< QVariant > &) |
QList< QVariant > | seriesPlotCorner () const |
Get/Set the plot-corner for each of the series. More... | |
void | setSeriesPlotCorner (const QList< QVariant > &) |
pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqPropertyWidget () override | |
virtual void | apply () |
virtual void | reset () |
virtual void | updateWidget (bool showing_advanced_properties) |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual char * | panelVisibility () const |
Forward calls to vtkSMProperty. More... | |
virtual void | setPanelVisibility (const char *vis) |
virtual bool | isSingleRowItem () const |
Determines if the PropertyWidget must be constructed using a single row. More... | |
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
Provides access to the decorators for this widget. More... | |
void | setProperty (vtkSMProperty *property) |
virtual void | select () |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More... | |
virtual void | selectPort (int portIndex) |
virtual void | deselect () |
bool | isSelected () const |
Properties | |
QList< QVariant > | seriesVisibility |
QList< QVariant > | presetLabel |
QList< QVariant > | seriesLabel |
QList< QVariant > | seriesColor |
QList< QVariant > | seriesOpacity |
QList< QVariant > | presetColor |
QList< QVariant > | seriesLineThickness |
QList< QVariant > | seriesLineStyle |
QList< QVariant > | seriesMarkerStyle |
QList< QVariant > | seriesMarkerSize |
QList< QVariant > | seriesPlotCorner |
virtual void | setView (pqView *) |
called to set the active view. More... | |
template<class T > | |
static QString | getXMLName (T *object) |
Description: This static utility method returns the XML name for an object as a QString. More... | |
static QString | getTooltip (vtkSMProperty *property) |
Returns the tooltip to use for the property. More... | |
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
Helper method to return value from WidgetHeight XML hint, if any. More... | |
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
Parse a XML element as a list of label to use for this widget. More... | |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More... | |
void | addDecorator (pqPropertyWidgetDecorator *) |
Register a decorator. More... | |
void | removeDecorator (pqPropertyWidgetDecorator *) |
Unregisters a decorator. More... | |
pqPropertyLinks & | links () |
Provides access to the pqPropertyLinks instance. More... | |
It works with a property-group with properties for various functions, including required properties (SeriesVisibility) and optional properties (SeriesLabel, SeriesColor, SeriesLineThickness, SeriesLineStyle, SeriesMarkerStyle, and SeriesPlotCorner). If any of optional property functions are missing from the group, the corresponding widgets will be hidden.
Definition at line 23 of file pqSeriesEditorPropertyWidget.h.
pqSeriesEditorPropertyWidget::pqSeriesEditorPropertyWidget | ( | vtkSMProxy * | proxy, |
vtkSMPropertyGroup * | smgroup, | ||
QWidget * | parent = nullptr |
QList<QVariant> pqSeriesEditorPropertyWidget::seriesVisibility | ( | ) | const |
void pqSeriesEditorPropertyWidget::setSeriesVisibility | ( | const QList< QVariant > & | ) |
QList<QVariant> pqSeriesEditorPropertyWidget::seriesColor | ( | ) | const |
void pqSeriesEditorPropertyWidget::setSeriesColor | ( | const QList< QVariant > & | ) |
QList<QVariant> pqSeriesEditorPropertyWidget::presetColor | ( | ) | const |
void pqSeriesEditorPropertyWidget::setPresetColor | ( | const QList< QVariant > & | ) |
QList<QVariant> pqSeriesEditorPropertyWidget::seriesOpacity | ( | ) | const |
void pqSeriesEditorPropertyWidget::setSeriesOpacity | ( | const QList< QVariant > & | ) |
QList<QVariant> pqSeriesEditorPropertyWidget::seriesLabel | ( | ) | const |
void pqSeriesEditorPropertyWidget::setSeriesLabel | ( | const QList< QVariant > & | ) |
QList<QVariant> pqSeriesEditorPropertyWidget::presetLabel | ( | ) | const |
void pqSeriesEditorPropertyWidget::setPresetLabel | ( | const QList< QVariant > & | ) |
QList<QVariant> pqSeriesEditorPropertyWidget::seriesLineThickness | ( | ) | const |
void pqSeriesEditorPropertyWidget::setSeriesLineThickness | ( | const QList< QVariant > & | ) |
QList<QVariant> pqSeriesEditorPropertyWidget::seriesLineStyle | ( | ) | const |
void pqSeriesEditorPropertyWidget::setSeriesLineStyle | ( | const QList< QVariant > & | ) |
QList<QVariant> pqSeriesEditorPropertyWidget::seriesMarkerStyle | ( | ) | const |
void pqSeriesEditorPropertyWidget::setSeriesMarkerStyle | ( | const QList< QVariant > & | ) |
QList<QVariant> pqSeriesEditorPropertyWidget::seriesMarkerSize | ( | ) | const |
void pqSeriesEditorPropertyWidget::setSeriesMarkerSize | ( | const QList< QVariant > & | ) |
QList<QVariant> pqSeriesEditorPropertyWidget::seriesPlotCorner | ( | ) | const |
void pqSeriesEditorPropertyWidget::setSeriesPlotCorner | ( | const QList< QVariant > & | ) |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
signal |
readwrite |
Definition at line 27 of file pqSeriesEditorPropertyWidget.h.
readwrite |
Definition at line 30 of file pqSeriesEditorPropertyWidget.h.
readwrite |
Definition at line 33 of file pqSeriesEditorPropertyWidget.h.
readwrite |
Definition at line 36 of file pqSeriesEditorPropertyWidget.h.
readwrite |
Definition at line 39 of file pqSeriesEditorPropertyWidget.h.
readwrite |
Definition at line 42 of file pqSeriesEditorPropertyWidget.h.
readwrite |
Definition at line 45 of file pqSeriesEditorPropertyWidget.h.
readwrite |
Definition at line 48 of file pqSeriesEditorPropertyWidget.h.
readwrite |
Definition at line 51 of file pqSeriesEditorPropertyWidget.h.
readwrite |
Definition at line 54 of file pqSeriesEditorPropertyWidget.h.
readwrite |
Definition at line 57 of file pqSeriesEditorPropertyWidget.h.
