Public Member Functions | Protected Slots | List of all members
pqTextureSelectorPropertyWidget Class Reference
#include <pqTextureSelectorPropertyWidget.h>
Inheritance diagram for pqTextureSelectorPropertyWidget:
Collaboration diagram for pqTextureSelectorPropertyWidget:
 pqTextureSelectorPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr)
 ~pqTextureSelectorPropertyWidget () override=default
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
Protected Slots
void onTextureChanged (vtkSMProxy *texture)
void onPropertyChanged ()
void checkAttributes (bool tcoords, bool tangents)
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
Definition at line 22 of file pqTextureSelectorPropertyWidget.h.
◆ pqTextureSelectorPropertyWidget()
pqTextureSelectorPropertyWidget::pqTextureSelectorPropertyWidget ( vtkSMProxy proxy,
vtkSMProperty property,
QWidget *  parent = nullptr
◆ ~pqTextureSelectorPropertyWidget()
pqTextureSelectorPropertyWidget::~pqTextureSelectorPropertyWidget ( )
overridedefault
◆ onTextureChanged
void pqTextureSelectorPropertyWidget::onTextureChanged ( vtkSMProxy texture)
protectedslot
◆ onPropertyChanged
void pqTextureSelectorPropertyWidget::onPropertyChanged ( )
protectedslot
◆ checkAttributes
void pqTextureSelectorPropertyWidget::checkAttributes ( bool  tcoords,
bool  tangents
protectedslot
