Remoting
Views
vtkSMImageExtractWriterProxy.h
1
// SPDX-FileCopyrightText: Copyright (c) Kitware Inc.
// SPDX-License-Identifier: BSD-3-Clause
14
#ifndef vtkSMImageExtractWriterProxy_h
15
#define vtkSMImageExtractWriterProxy_h
16
17
vtkRemotingViewsModule.h
// needed for exports
18
vtkSMExtractWriterProxy.h
vtkSMExtractsController.h
// for SummaryParametersT type
20
21
VTKREMOTINGVIEWS_EXPORT
public
22
23
public
24
New
25
vtkTypeMacro(
26
void
PrintSelf
(ostream& os,
vtkIndent
indent)
override
27
32
bool
Write
* extractor)
override
33
bool
CanExtract
vtkSMProxy
* proxy)
override
bool
IsExtracting
vtkSMProxy
* proxy)
override
35
void
SetInput
vtkSMProxy
* proxy)
override
36
vtkSMProxy
GetInput
override
38
enum
CameraMode
40
41
Static = 0,
42
PhiTheta = 1,
43
45
47
override
48
49
void
CreateVTKObjects
override
50
51
using
SummaryParametersT
vtkSMExtractsController::SummaryParametersT
52
58
bool
WriteImage(
* extractor,
59
const
SummaryParametersT
& cameraParams =
SummaryParametersT
60
65
bool
WriteInternal(
66
* extractor,
const
SummaryParametersT
& params =
SummaryParametersT
67
72
const
char
* GetShortName(
const
std::string&
key
const
73
74
private
75
const
delete
76
void
operator=(
const
delete
77
78
79
#endif
Definition:
vtkRemotingViewsModule.h:15
vtkSMExtractWriterProxy::PrintSelf
extract writer for images or rendering results
Definition:
vtkSMImageExtractWriterProxy.h:21
std::map< std::string, std::string > SummaryParametersT
Called by vtkSMExtractWriterProxy subclasses to add an entry to the summary table.
Definition:
vtkSMExtractsController.h:209
abstract class defining extract writer proxy API
Definition:
vtkSMExtractWriterProxy.h:19
vtkSMExtractWriterProxy::GetInput
virtual vtkSMProxy * GetInput()=0
This is convenience method that gets called by vtkSMExtractsController to set the extract writer to e...
vtkIndent
vtkSMExtractWriterProxy::IsExtracting
virtual bool IsExtracting(vtkSMProxy *proxy)=0
Returns true this extract writer proxy is generating and extract from the provided proxy...
vtkSMProxy::New
static vtkSMProxy * New()
vtkSMProxy::CreateVTKObjects
virtual void CreateVTKObjects()
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
vtkSMProxy
Definition:
vtkSMProxy.h:140
vtkSMExtractWriterProxy::SetInput
virtual void SetInput(vtkSMProxy *proxy)=0
vtkSMExtractWriterProxy::Write
virtual bool Write(vtkSMExtractsController *extractor)=0
Generate the extract.
vtkSMImageExtractWriterProxy::CameraMode
CameraMode
Definition:
vtkSMImageExtractWriterProxy.h:39
vtkSMImageExtractWriterProxy::SummaryParametersT
vtkSMExtractsController::SummaryParametersT SummaryParametersT
Definition:
vtkSMImageExtractWriterProxy.h:51
controller for extract generation
Definition:
vtkSMExtractsController.h:45
vtkSMExtractWriterProxy::CanExtract
virtual bool CanExtract(vtkSMProxy *proxy)=0
Returns true if the provided proxy can be extracted/written by this writer.
key
key
1.8.13 on Fri Aug 1 2025
