10 #ifndef vtkSMPythonViewProxy_h 11 #define vtkSMPythonViewProxy_h 66 vtkTypeUInt32
PreRender(
bool interactive)
override;
80 #endif // vtkSMPythonViewProxy_h Superclass for all view proxies.
static vtkSMViewProxy * New()
virtual vtkRenderWindow * GetRenderWindow()
Return the vtkRenderWindow used by this view, if any.
virtual vtkImageData * CaptureWindowInternal(int magnificationX, int magnificationY)
Capture an image from the view's render window.
virtual vtkRenderWindowInteractor * GetInteractor()
Returns the interactor.
virtual vtkTypeUInt32 PreRender(bool vtkNotUsed(interactive))
This method is called before executing code that could cause a render on the underlying vtkPVView...
virtual void SetupInteractor(vtkRenderWindowInteractor *iren)
A client process need to set the interactor to enable interactivity.
helper class that make it easier to hook vtkRenderWindowInteractor and vtkSMViewProxy.
#define VTKREMOTINGVIEWSPYTHON_EXPORT
