vtkSIDirectoryProxy is the server-implementation for a vtkSMDirectory which will customly handle server file listing for the pull request More...
#include <vtkSIDirectoryProxy.h>
| typedef vtkSIProxy | Superclass |
Public Types inherited from vtkSIProxy | |
| typedef vtkSIObject | Superclass |
Public Types inherited from vtkSIObject | |
| void | Pull (vtkSMMessage *msg) override |
Public Member Functions inherited from vtkSIProxy | |
| void | AboutToDelete () override |
| This method is called before the deletion of the SIObject. More... | |
| void | Push (vtkSMMessage *msg) override |
| vtkSIProperty * | GetSIProperty (const char *name) |
| Provides access to the property helper. More... | |
| bool | IsNullProxy () |
| Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More... | |
| Triggers UpdateInformation() on vtkObject if possible. More... | |
| Called by vtkSMProxy::RecreateVTKObjects() to re-create the VTK objects. More... | |
| virtual bool | ExtendDefinition (const char *xml) |
| Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More... | |
| Returns access to the VTKObject pointer, if any. More... | |
| void | SetVTKObject (vtkObjectBase *) |
| Returns the VTKClassName. More... | |
| virtual void | AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method) |
| These methods are called to add/remove input connections by vtkSIInputProperty. More... | |
| virtual void | CleanInputs (const char *method) |
Public Member Functions inherited from vtkSIObject | |
| virtual void | Initialize (vtkPVSessionCore *session) |
| Initializes the instance. More... | |
| vtkClientServerInterpreter * | GetInterpreter () |
| Provides access to the Interpreter. More... | |
| vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) const |
| vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
| Convenience method to obtain a vtkObject subclass given its global id. More... | |
| virtual void | SetGlobalID (vtkTypeUInt32) |
| Get/Set the global id for this object. More... | |
| static vtkSIDirectoryProxy * | New () |
| static vtkSIDirectoryProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSIProxy | |
| static vtkSIProxy * | New () |
| static vtkSIProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSIObject | |
| static vtkSIObject * | New () |
| static vtkSIObject * | SafeDownCast (vtkObject *o) |
| vtkSIDirectoryProxy () | |
| ~vtkSIDirectoryProxy () override | |
| bool | ReadXMLProperty (vtkPVXMLElement *property_element) override |
| Parses the XML to create property/subproxy helpers. More... | |
Protected Member Functions inherited from vtkSIProxy | |
| vtkSIProxy () | |
| ~vtkSIProxy () override | |
| virtual vtkObjectBase * | NewVTKObject (const char *className) |
| Create an instance of the class specified. More... | |
| vtkSIProxy * | GetSubSIProxy (const char *name) |
| Returns the subproxy helper for the subproxy with the given name, if any. More... | |
| vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
| Provides access to the vtkSIProxyDefinitionManager held by the session. More... | |
| virtual bool | CreateVTKObjects () |
| Creates the VTK objects. More... | |
| virtual void | DeleteVTKObjects () |
| Called to delete VTK objects. More... | |
| virtual void | OnCreateVTKObjects () |
| Called after CreateVTKObjects(). More... | |
| bool | InitializeAndCreateVTKObjects (vtkSMMessage *message) |
| Called by vtkSIProxy::Push() to ensure that the vtkSIProxy has been initialized. More... | |
| void | AddSIProperty (const char *name, vtkSIProperty *) |
| Adds a vtkSMProperty's server-implementation. More... | |
| virtual void | SetPostPush (const char *) |
| virtual void | SetPostCreation (const char *) |
| unsigned int | GetNumberOfSubSIProxys () |
| API to iterate over subproxy helpers. More... | |
| vtkSIProxy * | GetSubSIProxy (unsigned int cc) |
| virtual bool | ReadXMLAttributes (vtkPVXMLElement *element) |
| virtual bool | ReadXMLSubProxy (vtkPVXMLElement *subproxy_element) |
Protected Member Functions inherited from vtkSIObject | |
| vtkSIObject () | |
| ~vtkSIObject () override | |
Protected Attributes inherited from vtkSIProxy | |
| char * | VTKClassName |
| char * | XMLGroup |
| char * | XMLName |
| char * | XMLSubProxyName |
| char * | PostPush |
| char * | PostCreation |
| int | NumberOfInputPorts |
| vtkSmartPointer< vtkObjectBase > | VTKObject |
| bool | ObjectsCreated |
Protected Attributes inherited from vtkSIObject | |
| vtkWeakPointer< vtkClientServerInterpreter > | Interpreter |
| vtkWeakPointer< vtkPVSessionCore > | SessionCore |
| vtkSMMessage * | LastPushedMessage |
| vtkTypeUInt32 | GlobalID |
Definition at line 21 of file vtkSIDirectoryProxy.h.
Definition at line 25 of file vtkSIDirectoryProxy.h.
Reimplemented from vtkSIProxy.
Reimplemented from vtkSIObject.
overrideprotectedvirtual |
1.8.13 on Sun Dec 14 2025
