vtkSISourceProxy for all VTKPythonAlgorithmBase-based algorithms.
#include <vtkSIPythonSourceProxy.h>
| typedef vtkSISourceProxy | Superclass |
Public Types inherited from vtkSISourceProxy | |
| typedef vtkSIProxy | Superclass |
Public Types inherited from vtkSIProxy | |
| typedef vtkSIObject | Superclass |
Public Types inherited from vtkSIObject | |
| void | Push (vtkSMMessage *) override |
| void | Pull (vtkSMMessage *) override |
| void | RecreateVTKObjects () override |
| Overridden to update the output ports. More... | |
| void | Initialize (vtkPVSessionCore *session) override |
| Initializes the instance. More... | |
Public Member Functions inherited from vtkSISourceProxy | |
| virtual vtkAlgorithmOutput * | GetOutputPort (int port) |
| Returns the vtkAlgorithmOutput for an output port, if valid. More... | |
| void | UpdatePipelineInformation () override |
| Triggers UpdateInformation() on vtkObject if possible. More... | |
| virtual void | UpdatePipeline (int port, double time, bool doTime) |
| Triggers UpdatePipeline(). More... | |
| virtual void | SetupSelectionProxy (int port, vtkSIProxy *extractSelection) |
| setups extract selection proxies. More... | |
| virtual void | SetDisablePipelineExecution (bool value) |
| Allow to shut down pipeline execution. More... | |
Public Member Functions inherited from vtkSIProxy | |
| void | AboutToDelete () override |
| This method is called before the deletion of the SIObject. More... | |
| vtkSIProperty * | GetSIProperty (const char *name) |
| Provides access to the property helper. More... | |
| bool | IsNullProxy () |
| Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More... | |
| virtual bool | ExtendDefinition (const char *xml) |
| Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More... | |
| Returns access to the VTKObject pointer, if any. More... | |
| void | SetVTKObject (vtkObjectBase *) |
| Returns the VTKClassName. More... | |
| virtual void | AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method) |
| These methods are called to add/remove input connections by vtkSIInputProperty. More... | |
| virtual void | CleanInputs (const char *method) |
Public Member Functions inherited from vtkSIObject | |
| vtkClientServerInterpreter * | GetInterpreter () |
| Provides access to the Interpreter. More... | |
| vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) const |
| vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
| Convenience method to obtain a vtkObject subclass given its global id. More... | |
| virtual void | SetGlobalID (vtkTypeUInt32) |
| Get/Set the global id for this object. More... | |
| static vtkSIPythonSourceProxy * | New () |
| static vtkSIPythonSourceProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSISourceProxy | |
| static vtkSISourceProxy * | New () |
| static vtkSISourceProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSIProxy | |
| static vtkSIProxy * | New () |
| static vtkSIProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSIObject | |
| static vtkSIObject * | New () |
| static vtkSIObject * | SafeDownCast (vtkObject *o) |
| vtkSIPythonSourceProxy () | |
| ~vtkSIPythonSourceProxy () override | |
| vtkObjectBase * | NewVTKObject (const char *className) override |
| Overridden to use the Python interpreter to instantiate Python classes. More... | |
| void | DeleteVTKObjects () override |
| Overridden to release any Python objects created. More... | |
Protected Member Functions inherited from vtkSISourceProxy | |
| vtkSISourceProxy () | |
| ~vtkSISourceProxy () override | |
| bool | CreateVTKObjects () override |
| Overridden to setup the output ports and pipelines for the output ports. More... | |
| bool | ReadXMLAttributes (vtkPVXMLElement *element) override |
| Read xml-attributes. More... | |
| void | OnCreateVTKObjects () override |
| Called after CreateVTKObjects(). More... | |
| virtual bool | CreateOutputPorts () |
| Create the output ports and add post filters for each output port. More... | |
| virtual void | SetExecutiveName (const char *) |
| void | MarkStartEvent () |
| Callbacks to add start/end events to the timer log. More... | |
| void | MarkEndEvent () |
Protected Member Functions inherited from vtkSIProxy | |
| vtkSIProxy () | |
| ~vtkSIProxy () override | |
| vtkSIProxy * | GetSubSIProxy (const char *name) |
| Returns the subproxy helper for the subproxy with the given name, if any. More... | |
| vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
| Provides access to the vtkSIProxyDefinitionManager held by the session. More... | |
| bool | InitializeAndCreateVTKObjects (vtkSMMessage *message) |
| Called by vtkSIProxy::Push() to ensure that the vtkSIProxy has been initialized. More... | |
| void | AddSIProperty (const char *name, vtkSIProperty *) |
| Adds a vtkSMProperty's server-implementation. More... | |
| virtual void | SetPostPush (const char *) |
| virtual void | SetPostCreation (const char *) |
| unsigned int | GetNumberOfSubSIProxys () |
| API to iterate over subproxy helpers. More... | |
| vtkSIProxy * | GetSubSIProxy (unsigned int cc) |
| virtual bool | ReadXMLProperty (vtkPVXMLElement *property_element) |
| Parses the XML to create property/subproxy helpers. More... | |
| virtual bool | ReadXMLSubProxy (vtkPVXMLElement *subproxy_element) |
Protected Member Functions inherited from vtkSIObject | |
| vtkSIObject () | |
| ~vtkSIObject () override | |
Protected Attributes inherited from vtkSISourceProxy | |
| char * | ExecutiveName |
| bool | DisablePipelineExecution |
Protected Attributes inherited from vtkSIProxy | |
| char * | VTKClassName |
| char * | XMLGroup |
| char * | XMLName |
| char * | XMLSubProxyName |
| char * | PostPush |
| char * | PostCreation |
| int | NumberOfInputPorts |
| vtkSmartPointer< vtkObjectBase > | VTKObject |
| bool | ObjectsCreated |
Protected Attributes inherited from vtkSIObject | |
| vtkWeakPointer< vtkClientServerInterpreter > | Interpreter |
| vtkWeakPointer< vtkPVSessionCore > | SessionCore |
| vtkSMMessage * | LastPushedMessage |
| vtkTypeUInt32 | GlobalID |
vtkSIPythonSourceProxy makes is possible to work with a VTKPythonAlgorithmBase-based Python class in ParaView. By handling the push/pull APIs to forward the calls to the Python object, we can make such Python algorithms behave like regular C++-based algorithm subclasses.
Definition at line 23 of file vtkSIPythonSourceProxy.h.
Definition at line 27 of file vtkSIPythonSourceProxy.h.
Reimplemented from vtkSISourceProxy.
Reimplemented from vtkSIProxy.
Session is the session to which this instance belongs to. During initialization, the SIObject basically obtains ivars for necessary components.
Reimplemented from vtkSIObject.
overrideprotectedvirtual |
1.8.13 on Sat Dec 13 2025
