ServerImplementation for WriterProxy. More...
#include <vtkSIWriterProxy.h>
| typedef vtkSISourceProxy | Superclass |
Public Types inherited from vtkSISourceProxy | |
| typedef vtkSIProxy | Superclass |
Public Types inherited from vtkSIProxy | |
| typedef vtkSIObject | Superclass |
Public Types inherited from vtkSIObject | |
| virtual void | UpdatePipelineTime (double time) |
| Update the requested time for the pipeline. More... | |
| void | AddInput (int input_port, vtkAlgorithmOutput *connection, const char *method) override |
| These methods are called to add/remove input connections by vtkSIInputProperty. More... | |
| void | CleanInputs (const char *method) override |
Public Member Functions inherited from vtkSISourceProxy | |
| virtual vtkAlgorithmOutput * | GetOutputPort (int port) |
| Returns the vtkAlgorithmOutput for an output port, if valid. More... | |
| void | UpdatePipelineInformation () override |
| Triggers UpdateInformation() on vtkObject if possible. More... | |
| virtual void | UpdatePipeline (int port, double time, bool doTime) |
| Triggers UpdatePipeline(). More... | |
| virtual void | SetupSelectionProxy (int port, vtkSIProxy *extractSelection) |
| setups extract selection proxies. More... | |
| virtual void | SetDisablePipelineExecution (bool value) |
| Allow to shut down pipeline execution. More... | |
| void | RecreateVTKObjects () override |
| Overridden to update the output ports. More... | |
Public Member Functions inherited from vtkSIProxy | |
| void | AboutToDelete () override |
| This method is called before the deletion of the SIObject. More... | |
| void | Push (vtkSMMessage *msg) override |
| void | Pull (vtkSMMessage *msg) override |
| vtkSIProperty * | GetSIProperty (const char *name) |
| Provides access to the property helper. More... | |
| bool | IsNullProxy () |
| Return true if that Proxy is supposed to have NO vtk class, which means its a NullProxy. More... | |
| virtual bool | ExtendDefinition (const char *xml) |
| Counter part to vtkSMSelfGeneratingSourceProxy::ExtendDefinition(). More... | |
| Returns access to the VTKObject pointer, if any. More... | |
| void | SetVTKObject (vtkObjectBase *) |
| Returns the VTKClassName. More... | |
Public Member Functions inherited from vtkSIObject | |
| virtual void | Initialize (vtkPVSessionCore *session) |
| Initializes the instance. More... | |
| vtkClientServerInterpreter * | GetInterpreter () |
| Provides access to the Interpreter. More... | |
| vtkSIObject * | GetSIObject (vtkTypeUInt32 globalid) const |
| vtkObject * | GetRemoteObject (vtkTypeUInt32 globalid) |
| Convenience method to obtain a vtkObject subclass given its global id. More... | |
| virtual void | SetGlobalID (vtkTypeUInt32) |
| Get/Set the global id for this object. More... | |
| static vtkSIWriterProxy * | New () |
| static vtkSIWriterProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSISourceProxy | |
| static vtkSISourceProxy * | New () |
| static vtkSISourceProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSIProxy | |
| static vtkSIProxy * | New () |
| static vtkSIProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSIObject | |
| static vtkSIObject * | New () |
| static vtkSIObject * | SafeDownCast (vtkObject *o) |
| vtkSIWriterProxy () | |
| ~vtkSIWriterProxy () override | |
| void | OnCreateVTKObjects () override |
| Overridden to setup stuff on the writer e.g piece request, gather helpers etc. More... | |
| bool | ReadXMLAttributes (vtkPVXMLElement *element) override |
| Read xml-attributes. More... | |
| virtual void | SetFileNameMethod (const char *) |
Protected Member Functions inherited from vtkSISourceProxy | |
| vtkSISourceProxy () | |
| ~vtkSISourceProxy () override | |
| bool | CreateVTKObjects () override |
| Overridden to setup the output ports and pipelines for the output ports. More... | |
| virtual bool | CreateOutputPorts () |
| Create the output ports and add post filters for each output port. More... | |
| virtual void | SetExecutiveName (const char *) |
| void | MarkStartEvent () |
| Callbacks to add start/end events to the timer log. More... | |
| void | MarkEndEvent () |
Protected Member Functions inherited from vtkSIProxy | |
| vtkSIProxy () | |
| ~vtkSIProxy () override | |
| virtual vtkObjectBase * | NewVTKObject (const char *className) |
| Create an instance of the class specified. More... | |
| vtkSIProxy * | GetSubSIProxy (const char *name) |
| Returns the subproxy helper for the subproxy with the given name, if any. More... | |
| vtkSIProxyDefinitionManager * | GetProxyDefinitionManager () |
| Provides access to the vtkSIProxyDefinitionManager held by the session. More... | |
| virtual void | DeleteVTKObjects () |
| Called to delete VTK objects. More... | |
| bool | InitializeAndCreateVTKObjects (vtkSMMessage *message) |
| Called by vtkSIProxy::Push() to ensure that the vtkSIProxy has been initialized. More... | |
| void | AddSIProperty (const char *name, vtkSIProperty *) |
| Adds a vtkSMProperty's server-implementation. More... | |
| virtual void | SetPostPush (const char *) |
| virtual void | SetPostCreation (const char *) |
| unsigned int | GetNumberOfSubSIProxys () |
| API to iterate over subproxy helpers. More... | |
| vtkSIProxy * | GetSubSIProxy (unsigned int cc) |
| virtual bool | ReadXMLProperty (vtkPVXMLElement *property_element) |
| Parses the XML to create property/subproxy helpers. More... | |
| virtual bool | ReadXMLSubProxy (vtkPVXMLElement *subproxy_element) |
Protected Member Functions inherited from vtkSIObject | |
| vtkSIObject () | |
| ~vtkSIObject () override | |
Protected Attributes | |
| char * | FileNameMethod |
Protected Attributes inherited from vtkSISourceProxy | |
| char * | ExecutiveName |
| bool | DisablePipelineExecution |
Protected Attributes inherited from vtkSIProxy | |
| char * | VTKClassName |
| char * | XMLGroup |
| char * | XMLName |
| char * | XMLSubProxyName |
| char * | PostPush |
| char * | PostCreation |
| int | NumberOfInputPorts |
| vtkSmartPointer< vtkObjectBase > | VTKObject |
| bool | ObjectsCreated |
Protected Attributes inherited from vtkSIObject | |
| vtkWeakPointer< vtkClientServerInterpreter > | Interpreter |
| vtkWeakPointer< vtkPVSessionCore > | SessionCore |
| vtkSMMessage * | LastPushedMessage |
| vtkTypeUInt32 | GlobalID |
Definition at line 15 of file vtkSIWriterProxy.h.
Definition at line 19 of file vtkSIWriterProxy.h.
Reimplemented from vtkSISourceProxy.
This indirection makes it possible for subclasses to insert VTK-algorithms in the input pipeline. Overridden to insert "CompleteArrays" filter in the pipeline.
Reimplemented from vtkSIProxy.
This needs to be separate than vtkSISourceProxy because there are no output ports to do this on.
overrideprotectedvirtual |
protectedvirtual |
Definition at line 55 of file vtkSIWriterProxy.h.
1.8.13 on Sun Dec 14 2025
