vtkSMBoxRepresentationProxy Class Reference
proxy for vtkBoxRepresentation More...
#include <vtkSMBoxRepresentationProxy.h>
Inheritance diagram for vtkSMBoxRepresentationProxy:
Collaboration diagram for vtkSMBoxRepresentationProxy:
typedef vtkSMWidgetRepresentationProxy Superclass
- Public Types inherited from vtkSMWidgetRepresentationProxy
typedef vtkSMProxy Superclass
void UpdateVTKObjects () override
void UpdatePropertyInformation () override
void UpdatePropertyInformation (vtkSMProperty *prop) override
- Public Member Functions inherited from vtkSMWidgetRepresentationProxy
virtual void OnStartInteraction ()
 These method forward the representation state of the client side widget representation to the server. More...
virtual void OnEndInteraction ()
virtual void OnInteraction ()
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMBoxRepresentationProxyNew ()
static vtkSMBoxRepresentationProxySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMWidgetRepresentationProxy
static vtkSMWidgetRepresentationProxyNew ()
static vtkSMWidgetRepresentationProxySafeDownCast (vtkObject *o)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMBoxRepresentationProxy ()
 ~vtkSMBoxRepresentationProxy () override
- Protected Member Functions inherited from vtkSMWidgetRepresentationProxy
 vtkSMWidgetRepresentationProxy ()
 ~vtkSMWidgetRepresentationProxy () override
virtual void SendRepresentation ()
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMWidgetRepresentationProxy
int RepresentationState
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMBoxRepresentationProxy is a proxy for vtkBoxRepresentation. A specialization is needed to set the transform on the vtkBoxRepresentation. Since vtkBoxRepresentation::SetTranform is really akin to ApplyTransform, the transform must be set each time the transform changes or the widget is placed using PlaceWidget or something like that.
Definition at line 20 of file vtkSMBoxRepresentationProxy.h.
Definition at line 24 of file vtkSMBoxRepresentationProxy.h.
◆ vtkSMBoxRepresentationProxy()
vtkSMBoxRepresentationProxy::vtkSMBoxRepresentationProxy ( )
◆ ~vtkSMBoxRepresentationProxy()
vtkSMBoxRepresentationProxy::~vtkSMBoxRepresentationProxy ( )
static vtkSMBoxRepresentationProxy* vtkSMBoxRepresentationProxy::New ( )
virtual const char* vtkSMBoxRepresentationProxy::GetClassName ( )
Reimplemented from vtkSMWidgetRepresentationProxy.
static int vtkSMBoxRepresentationProxy::IsTypeOf ( const char *  type)
virtual int vtkSMBoxRepresentationProxy::IsA ( const char *  type)
static vtkSMBoxRepresentationProxy* vtkSMBoxRepresentationProxy::SafeDownCast ( vtkObject o)
void vtkSMBoxRepresentationProxy::PrintSelf ( ostream &  os,
◆ UpdateVTKObjects()
void vtkSMBoxRepresentationProxy::UpdateVTKObjects ( )
Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored).
If the object has not been created, it will be created first.
◆ UpdatePropertyInformation() [1/2]
void vtkSMBoxRepresentationProxy::UpdatePropertyInformation ( )
Updates all property information by calling UpdateInformation() and populating the values.
◆ UpdatePropertyInformation() [2/2]
void vtkSMBoxRepresentationProxy::UpdatePropertyInformation ( vtkSMProperty prop)
inlineoverridevirtual
Similar to UpdatePropertyInformation() but updates only the given property.
If the property does not belong to the proxy, the call is ignored.
Definition at line 29 of file vtkSMBoxRepresentationProxy.h.
◆ CreateVTKObjects()
void vtkSMBoxRepresentationProxy::CreateVTKObjects ( )
overrideprotectedvirtual
Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s)
