vtkSMCSVExporterProxy Class Reference
exporter used to export the spreadsheet view and supported chart views as to a CSV file. More...
#include <vtkSMCSVExporterProxy.h>
Inheritance diagram for vtkSMCSVExporterProxy:
Collaboration diagram for vtkSMCSVExporterProxy:
typedef vtkSMExporterProxy Superclass
- Public Types inherited from vtkSMExporterProxy
typedef vtkSMProxy Superclass
void Write () override
 Exports the view. More...
bool CanExport (vtkSMProxy *) override
 Returns if the view can be exported. More...
- Public Member Functions inherited from vtkSMExporterProxy
virtual void SetView (vtkSMViewProxy *view)
 Set the view proxy to export. More...
virtual vtkSMViewProxyGetView ()
const std::vector< std::string > & GetFileExtensions () const
 Returns the suggested file extensions for this exporter. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMCSVExporterProxyNew ()
static vtkSMCSVExporterProxySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExporterProxy
static vtkSMExporterProxySafeDownCast (vtkObject *o)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMCSVExporterProxy ()
 ~vtkSMCSVExporterProxy () override
- Protected Member Functions inherited from vtkSMExporterProxy
 vtkSMExporterProxy ()
 ~vtkSMExporterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
- Protected Attributes inherited from vtkSMExporterProxy
vtkSMViewProxyView
std::vector< std::stringFileExtensions
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
vtkSMCSVExporterProxy is used to export the certain views to a CSV file. Currently, we support vtkSpreadSheetView and vtkPVXYChartView (which includes Bar/Line/Quartile/Parallel Coordinates views).
See also
vtkCSVExporter
Definition at line 21 of file vtkSMCSVExporterProxy.h.
Definition at line 25 of file vtkSMCSVExporterProxy.h.
◆ vtkSMCSVExporterProxy()
vtkSMCSVExporterProxy::vtkSMCSVExporterProxy ( )
◆ ~vtkSMCSVExporterProxy()
vtkSMCSVExporterProxy::~vtkSMCSVExporterProxy ( )
static vtkSMCSVExporterProxy* vtkSMCSVExporterProxy::New ( )
virtual const char* vtkSMCSVExporterProxy::GetClassName ( )
Reimplemented from vtkSMExporterProxy.
static int vtkSMCSVExporterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMCSVExporterProxy::IsA ( const char *  type)
static vtkSMCSVExporterProxy* vtkSMCSVExporterProxy::SafeDownCast ( vtkObject o)
void vtkSMCSVExporterProxy::PrintSelf ( ostream &  os,
◆ Write()
void vtkSMCSVExporterProxy::Write ( )
Exports the view.
Implements vtkSMExporterProxy.
◆ CanExport()
bool vtkSMCSVExporterProxy::CanExport ( vtkSMProxy )
Default implementation return true if the view is a render view.
