virtual bool | IsActivated (vtkSMExtractsController *controller) |
| Returns true if the trigger conditions are satisfied. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
