vtkSMVRResetTransformStyleProxy Class Reference
#include <vtkSMVRResetTransformStyleProxy.h>
Inheritance diagram for vtkSMVRResetTransformStyleProxy:
Collaboration diagram for vtkSMVRResetTransformStyleProxy:
typedef vtkSMVRTrackStyleProxy Superclass
- Public Types inherited from vtkSMVRTrackStyleProxy
enum  { INTERACTOR_STYLE_REQUEST_CONFIGURE = vtkCommand::UserEvent + 7370, INTERACTOR_STYLE_NAVIGATION = vtkCommand::UserEvent + 7371 }
typedef vtkSMProxy Superclass
typedef std::map< std::string, std::stringStringMap
typedef std::map< std::string, StringMapStringMapMap
- Public Member Functions inherited from vtkSMVRTrackStyleProxy
int GetControlledPropertySize () override
virtual vtkSMProxyGetControlledProxy ()
virtual void SetIsInternal (bool)
virtual bool GetIsInternal ()
virtual void IsInternalOn ()
virtual void IsInternalOff ()
virtual bool Update ()
int GetNumberOfButtonRoles ()
unsigned int GetChannelIndexForValuatorRole (const std::string &role)
void ClearAllRoles ()
virtual vtkPVXMLElementSaveConfiguration ()
 Save state to xml. More...
vtkMatrix4x4GetNavigationMatrix ()
void SetNavigationMatrix (vtkMatrix4x4 *)
void SetValuatorLookupTable (std::shared_ptr< StringMapMap >)
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMVRResetTransformStyleProxyNew ()
static vtkSMVRResetTransformStyleProxySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMVRTrackStyleProxy
static vtkSMVRTrackStyleProxyNew ()
static vtkSMVRTrackStyleProxySafeDownCast (vtkObject *o)
static vtkSMVRInteractorStyleProxyNew ()
static vtkSMVRInteractorStyleProxySafeDownCast (vtkObject *o)
static vtkSMRenderViewProxyGetActiveViewProxy ()
static vtkCameraGetActiveCamera ()
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMVRResetTransformStyleProxy ()
 ~vtkSMVRResetTransformStyleProxy () override
void HandleButton (const vtkVREvent &event) override
void HandleTracker (const vtkVREvent &event) override
- Protected Member Functions inherited from vtkSMVRTrackStyleProxy
 vtkSMVRTrackStyleProxy ()
 ~vtkSMVRTrackStyleProxy () override
virtual void HandleValuator (const vtkVREvent &event)
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
bool EnableNavigate
bool IsInitialRecorded
vtkNew< vtkMatrix4x4SavedModelViewMatrix
vtkNew< vtkMatrix4x4SavedInverseWandMatrix
vtkSMProxyControlledProxy
char * ControlledPropertyName
StringMap Valuators
StringMap Buttons
StringMap Trackers
bool IsInternal
std::shared_ptr< StringMapMapvaluatorLookupTable
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
static std::vector< std::stringTokenize (std::string input)
Definition at line 18 of file vtkSMVRResetTransformStyleProxy.h.
Definition at line 23 of file vtkSMVRResetTransformStyleProxy.h.
◆ vtkSMVRResetTransformStyleProxy()
vtkSMVRResetTransformStyleProxy::vtkSMVRResetTransformStyleProxy ( )
◆ ~vtkSMVRResetTransformStyleProxy()
vtkSMVRResetTransformStyleProxy::~vtkSMVRResetTransformStyleProxy ( )
static vtkSMVRResetTransformStyleProxy* vtkSMVRResetTransformStyleProxy::New ( )
virtual const char* vtkSMVRResetTransformStyleProxy::GetClassName ( )
Reimplemented from vtkSMVRTrackStyleProxy.
static int vtkSMVRResetTransformStyleProxy::IsTypeOf ( const char *  type)
virtual int vtkSMVRResetTransformStyleProxy::IsA ( const char *  type)
static vtkSMVRResetTransformStyleProxy* vtkSMVRResetTransformStyleProxy::SafeDownCast ( vtkObject o)
void vtkSMVRResetTransformStyleProxy::PrintSelf ( ostream &  os,
◆ HandleButton()
void vtkSMVRResetTransformStyleProxy::HandleButton ( const vtkVREvent event)
overrideprotectedvirtual
◆ HandleTracker()
void vtkSMVRResetTransformStyleProxy::HandleTracker ( const vtkVREvent event)
◆ EnableNavigate
bool vtkSMVRResetTransformStyleProxy::EnableNavigate
Definition at line 33 of file vtkSMVRResetTransformStyleProxy.h.
◆ IsInitialRecorded
bool vtkSMVRResetTransformStyleProxy::IsInitialRecorded
Definition at line 34 of file vtkSMVRResetTransformStyleProxy.h.
◆ SavedModelViewMatrix
vtkNew<vtkMatrix4x4> vtkSMVRResetTransformStyleProxy::SavedModelViewMatrix
Definition at line 36 of file vtkSMVRResetTransformStyleProxy.h.
◆ SavedInverseWandMatrix
vtkNew<vtkMatrix4x4> vtkSMVRResetTransformStyleProxy::SavedInverseWandMatrix
Definition at line 37 of file vtkSMVRResetTransformStyleProxy.h.
