list of strings corresponding to the names of the arrays in the required input dataset that can be us...
int ReadXMLAttributes(vtkSMProperty *prop, vtkPVXMLElement *element) override
void Update(vtkSMProperty *) override
Update self checking the "unchecked" values of all required properties.
static vtkSMStringListDomain * New()
int SetDefaultValues(vtkSMProperty *, bool use_unchecked_values) override
