pqPropertyWidget subclass for properties with vtkSMArrayListDomain. More...
#include <pqArraySelectorPropertyWidget.h>
Public Slots | |
void | setArray (int assoc, const QString &val) |
Set the chosen array name and association. More... | |
void | setArray (const QList< QVariant > &val) |
A setArray overload useful to expose the setArray using Qt's property system. More... | |
void | setArrayName (const QString &name) |
Set the array name without caring for the array association. More... | |
virtual void | setView (pqView *) |
called to set the active view. More... | |
Signals | |
void | arrayChanged () |
void | viewChanged (pqView *view) |
This signal is emitted when the current view changes. More... | |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
pqArraySelectorPropertyWidget (vtkSMProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent=nullptr) | |
pqArraySelectorPropertyWidget (vtkSMProperty *smproperty, vtkSMProxy *smproxy, std::initializer_list< QPair< int, QString >> knownArrays, QWidget *parent=nullptr) | |
~pqArraySelectorPropertyWidget () override | |
QString | arrayName () const |
Returns the chosen array name. More... | |
int | arrayAssociation () const |
Returns the chosen array association. More... | |
QList< QVariant > | array () const |
Returns the {association, name} for the chosen array. More... | |
pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqPropertyWidget () override | |
virtual void | apply () |
virtual void | reset () |
virtual void | updateWidget (bool showing_advanced_properties) |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual char * | panelVisibility () const |
Forward calls to vtkSMProperty. More... | |
virtual void | setPanelVisibility (const char *vis) |
virtual bool | isSingleRowItem () const |
Determines if the PropertyWidget must be constructed using a single row. More... | |
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
Provides access to the decorators for this widget. More... | |
void | setProperty (vtkSMProperty *property) |
virtual void | select () |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More... | |
virtual void | selectPort (int portIndex) |
virtual void | deselect () |
bool | isSelected () const |
Properties | |
QList< QVariant > | array |
QString | arrayName |
template<class T > | |
static QString | getXMLName (T *object) |
Description: This static utility method returns the XML name for an object as a QString. More... | |
static QString | getTooltip (vtkSMProperty *property) |
Returns the tooltip to use for the property. More... | |
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
Helper method to return value from WidgetHeight XML hint, if any. More... | |
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
Parse a XML element as a list of label to use for this widget. More... | |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More... | |
void | addDecorator (pqPropertyWidgetDecorator *) |
Register a decorator. More... | |
void | removeDecorator (pqPropertyWidgetDecorator *) |
Unregisters a decorator. More... | |
pqPropertyLinks & | links () |
Provides access to the pqPropertyLinks instance. More... | |
pqArraySelectorPropertyWidget is intended to be used for vtkSMStringVectorProperty instances that have a vtkSMArrayListDomain domain and want to show a single combo-box to allow the user to choose the array to use.
We support non-repeatable string-vector property with a 1, 2, or 5 elements. When 1 element is present, we interpret the property value as the name of chosen array, thus the user won't be able to pick array association. While for 2 and 5 element properties the array association and name can be picked.
The list of available arrays is built using the vtkSMArrayListDomain and updated anytime the domain is updated. If the currently chosen value is no longer in the domain, we will preserve it and flag it by adding a (?)
suffix to the displayed label.
pqStringVectorPropertyWidget::createWidget
instantiates this for any string vector property with a vtkSMArrayListDomain that is not repeatable.
Pre-defined entries can be provided with the KnownArrays argument when constructing the widget.
Definition at line 38 of file pqArraySelectorPropertyWidget.h.
pqArraySelectorPropertyWidget::pqArraySelectorPropertyWidget | ( | vtkSMProperty * | smproperty, |
vtkSMProxy * | smproxy, | ||
QWidget * | parent = nullptr |
std::initializer_list< QPair< int, QString >> | knownArrays, | ||
QString pqArraySelectorPropertyWidget::arrayName | ( | ) | const |
int pqArraySelectorPropertyWidget::arrayAssociation | ( | ) | const |
QList<QVariant> pqArraySelectorPropertyWidget::array | ( | ) | const |
slot |
val
must be a two-tuple.
slot |
In general, this is only meant to be used for connecting to a SMProperty which only lets the user choose the array name and not the association.
signal |
readwrite |
Definition at line 43 of file pqArraySelectorPropertyWidget.h.
readwrite |
