pqFontPropertyWidget is a pqPropertyWidget that can be used to set properties relating to fonts. More...
#include <pqFontPropertyWidget.h>
Signals | |
void | horizontalJustificationChanged (QString &) |
void | verticalJustificationChanged (QString &) |
void | viewChanged (pqView *view) |
This signal is emitted when the current view changes. More... | |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
pqFontPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
~pqFontPropertyWidget () override | |
QString | HorizontalJustification () const |
QString | VerticalJustification () const |
pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr) | |
vtkSMPropertyGroup * | propertyGroup () const |
void | addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1) |
void | addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1) |
void | addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1) |
char * | panelVisibility () const override |
Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More... | |
void | setPanelVisibility (const char *vis) override |
pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqPropertyWidget () override | |
virtual void | apply () |
virtual void | reset () |
virtual void | updateWidget (bool showing_advanced_properties) |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual bool | isSingleRowItem () const |
Determines if the PropertyWidget must be constructed using a single row. More... | |
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
Provides access to the decorators for this widget. More... | |
void | setProperty (vtkSMProperty *property) |
virtual void | select () |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More... | |
virtual void | selectPort (int portIndex) |
virtual void | deselect () |
bool | isSelected () const |
Protected Slots | |
void | changeHorizontalJustificationIcon (QAction *) |
void | changeVerticalJustificationIcon (QAction *) |
void | onFontFamilyChanged () |
void | setHorizontalJustification (QString &) |
void | setVerticalJustification (QString &) |
void | setupHorizontalJustificationButton () |
void | setupVerticalJustificationButton () |
void | UpdateToolButtonIcon (QString &str, QToolButton *justification) |
QActionGroup * | CreateFontActionGroup (QToolButton *justification) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More... | |
void | addDecorator (pqPropertyWidgetDecorator *) |
Register a decorator. More... | |
void | removeDecorator (pqPropertyWidgetDecorator *) |
Unregisters a decorator. More... | |
pqPropertyLinks & | links () |
Provides access to the pqPropertyLinks instance. More... | |
Properties | |
QString | HorizontalJustification |
QString | VerticalJustification |
virtual void | setView (pqView *) |
called to set the active view. More... | |
template<class T > | |
static QString | getXMLName (T *object) |
Description: This static utility method returns the XML name for an object as a QString. More... | |
static QString | getTooltip (vtkSMProperty *property) |
Returns the tooltip to use for the property. More... | |
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
Helper method to return value from WidgetHeight XML hint, if any. More... | |
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
Parse a XML element as a list of label to use for this widget. More... | |
The widget expects the property-group to have properties with functions set to "Color", "Opacity", "Family", "Size", "Bold", "Italics" and "Shadow". If any property is missing, the corresponding widget will be hidden.
Definition at line 20 of file pqFontPropertyWidget.h.
pqFontPropertyWidget::pqFontPropertyWidget | ( | vtkSMProxy * | proxy, |
vtkSMPropertyGroup * | smgroup, | ||
QWidget * | parent = nullptr |
QString pqFontPropertyWidget::HorizontalJustification | ( | ) | const |
QString pqFontPropertyWidget::VerticalJustification | ( | ) | const |
signal |
signal |
protectedslot |
protectedslot |
protectedslot |
readwrite |
Definition at line 24 of file pqFontPropertyWidget.h.
readwrite |
Definition at line 26 of file pqFontPropertyWidget.h.
