Public Types | Public Member Functions | List of all members
pqMultiBlockPropertiesEditorWidget Class Reference
This is a pqPropertyGroupWidget subclass that presents a widget to edit several representation properties of a multi-block dataset. More...
#include <pqMultiBlockPropertiesEditorWidget.h>
Inheritance diagram for pqMultiBlockPropertiesEditorWidget:
Collaboration diagram for pqMultiBlockPropertiesEditorWidget:
typedef pqPropertyGroupWidget Superclass
 pqMultiBlockPropertiesEditorWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr)
 ~pqMultiBlockPropertiesEditorWidget () override
- Public Member Functions inherited from pqPropertyGroupWidget
 pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr)
vtkSMPropertyGrouppropertyGroup () const
void addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1)
void addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1)
void addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1)
void addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1)
void addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1)
void addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1)
char * panelVisibility () const override
 Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More...
void setPanelVisibility (const char *vis) override
 ~pqPropertyWidget () override
virtual void apply ()
virtual void reset ()
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
virtual void select ()
virtual void deselect ()
bool isSelected () const
void changeAvailable ()
void changeFinished ()
void restartRequired ()
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
It's used as the "widget" for BlockPropertiesEditor property group.
Definition at line 17 of file pqMultiBlockPropertiesEditorWidget.h.
Definition at line 21 of file pqMultiBlockPropertiesEditorWidget.h.
◆ pqMultiBlockPropertiesEditorWidget()
pqMultiBlockPropertiesEditorWidget::pqMultiBlockPropertiesEditorWidget ( vtkSMProxy proxy,
vtkSMPropertyGroup smGroup,
QWidget *  parent = nullptr
◆ ~pqMultiBlockPropertiesEditorWidget()
pqMultiBlockPropertiesEditorWidget::~pqMultiBlockPropertiesEditorWidget ( )
override
