Signals | Public Member Functions | Properties | List of all members
pqProxySelectionWidget Class Reference
pqPropertyWidget that can be used for any proxy with a vtkSMProxyListDomain. More...
#include <pqProxySelectionWidget.h>
Inheritance diagram for pqProxySelectionWidget:
Collaboration diagram for pqProxySelectionWidget:
Signals
void chosenProxyChanged ()
 Signal fired by setChosenProxy() when the proxy changes. More...
void changeAvailable ()
void changeFinished ()
void restartRequired ()
 pqProxySelectionWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr)
 constructor requires the proxy, property. More...
 ~pqProxySelectionWidget () override
vtkSMProxychosenProxy () const
 get the selected proxy More...
void setChosenProxy (vtkSMProxy *proxy)
void apply () override
 Overridden to forward the call to the internal pqProxyWidget maintained for the chosen proxy. More...
void reset () override
void select () override
void deselect () override
void updateWidget (bool showing_advanced_properties) override
void setPanelVisibility (const char *vis) override
void setView (pqView *) override
 ~pqPropertyWidget () override
pqViewview () const
vtkSMProxyproxy () const
vtkSMPropertyproperty () const
bool showLabel () const
bool isSelected () const
Properties
pqSMProxy chosenProxy
template<class T >
static std::vector< std::stringparseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0)
void setShowLabel (bool show)
 Register a decorator. More...
pqPropertyLinkslinks ()
pqProxyPropertyWidget automatically creates this widget when it encounters a property with vtkSMProxyListDomain.
Definition at line 21 of file pqProxySelectionWidget.h.
◆ pqProxySelectionWidget()
pqProxySelectionWidget::pqProxySelectionWidget ( vtkSMProperty property,
vtkSMProxy proxy,
QWidget *  parent = nullptr
Note that this will abort if the property does not have a ProxyListDomain.
◆ ~pqProxySelectionWidget()
pqProxySelectionWidget::~pqProxySelectionWidget ( )
override
◆ chosenProxy()
vtkSMProxy* pqProxySelectionWidget::chosenProxy ( ) const
◆ setChosenProxy()
void pqProxySelectionWidget::setChosenProxy ( vtkSMProxy proxy)
◆ apply()
void pqProxySelectionWidget::apply ( )
Reimplemented from pqPropertyWidget.
◆ reset()
void pqProxySelectionWidget::reset ( )
◆ select()
void pqProxySelectionWidget::select ( )
Only widgets that have interactive widgets need to override these methods to select/deselect the interactive widgets. selectPort(int) allows to specify an output port index and conditionnaly select the interactive widget if the XML hint WidgetVisibilityLink has been set. Default implementation does nothing.
◆ deselect()
void pqProxySelectionWidget::deselect ( )
◆ updateWidget()
void pqProxySelectionWidget::updateWidget ( bool  showing_advanced_properties)
◆ setPanelVisibility()
void pqProxySelectionWidget::setPanelVisibility ( const char *  vis)
◆ setView()
void pqProxySelectionWidget::setView ( pqView )
This will fire the viewChanged() signal.
◆ chosenProxyChanged
void pqProxySelectionWidget::chosenProxyChanged ( )
signal
Property Documentation
◆ chosenProxy
pqSMProxy pqProxySelectionWidget::chosenProxy
readwrite
Definition at line 25 of file pqProxySelectionWidget.h.
