pqSelectionListPropertyWidget is a custom widget used to associate a label for each selectionNode from an input selection. More...
#include <pqSelectionListPropertyWidget.h>
Signals | |
void | labelsChanged () |
Signal for the labels proxy changed. More... | |
void | viewChanged (pqView *view) |
This signal is emitted when the current view changes. More... | |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
pqSelectionListPropertyWidget (vtkSMProxy *smproxy, vtkSMPropertyGroup *smgroup, QWidget *parentObject=nullptr) | |
~pqSelectionListPropertyWidget () override | |
QList< QVariant > | labels () const |
Methods used to set/get the label values for the widget. More... | |
void | setLabels (const QList< QVariant > &labels) |
pqPropertyGroupWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smGroup, QWidget *parent=nullptr) | |
vtkSMPropertyGroup * | propertyGroup () const |
void | addPropertyLink (QComboBox *cb, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QLineEdit *edit, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QCheckBox *button, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QToolButton *button, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QGroupBox *groupBox, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QDoubleSpinBox *spinBox, const char *propertyName, int smindex=-1) |
void | addPropertyLink (QSpinBox *spinBox, const char *propertyName, int smindex=-1) |
void | addPropertyLink (pqColorChooserButton *color, const char *propertyName, int smindex=-1) |
void | addPropertyLink (pqDoubleSliderWidget *slider, const char *propertyName, int smindex=-1) |
char * | panelVisibility () const override |
Overwrite pqPropertyWidget to forward calls to vtkSMPropertyGroup. More... | |
void | setPanelVisibility (const char *vis) override |
pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqPropertyWidget () override | |
virtual void | apply () |
virtual void | reset () |
virtual void | updateWidget (bool showing_advanced_properties) |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual bool | isSingleRowItem () const |
Determines if the PropertyWidget must be constructed using a single row. More... | |
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
Provides access to the decorators for this widget. More... | |
void | setProperty (vtkSMProperty *property) |
virtual void | select () |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More... | |
virtual void | selectPort (int portIndex) |
virtual void | deselect () |
bool | isSelected () const |
Protected Slots | |
void | populateRowLabels (pqSMProxy appendSelection) |
Clone the active selection handled by the selection manager. More... | |
Properties | |
QList< QVariant > | labels |
virtual void | setView (pqView *) |
called to set the active view. More... | |
template<class T > | |
static QString | getXMLName (T *object) |
Description: This static utility method returns the XML name for an object as a QString. More... | |
static QString | getTooltip (vtkSMProperty *property) |
Returns the tooltip to use for the property. More... | |
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
Helper method to return value from WidgetHeight XML hint, if any. More... | |
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
Parse a XML element as a list of label to use for this widget. More... | |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More... | |
void | addDecorator (pqPropertyWidgetDecorator *) |
Register a decorator. More... | |
void | removeDecorator (pqPropertyWidgetDecorator *) |
Unregisters a decorator. More... | |
pqPropertyLinks & | links () |
Provides access to the pqPropertyLinks instance. More... | |
It also use the pqSelectionInputWidget to know the number of labels we need to define, by copying the active selection.
Definition at line 25 of file pqSelectionListPropertyWidget.h.
pqSelectionListPropertyWidget::pqSelectionListPropertyWidget | ( | vtkSMProxy * | smproxy, |
vtkSMPropertyGroup * | smgroup, | ||
QWidget * | parentObject = nullptr |
QList<QVariant> pqSelectionListPropertyWidget::labels | ( | ) | const |
The number of labels required depend of the number of SelectionNode in the activeSelection provided by the pqSelectionInputWidget.
void pqSelectionListPropertyWidget::setLabels | ( | const QList< QVariant > & | labels | ) |
signal |
protectedslot |
readwrite |
Definition at line 29 of file pqSelectionListPropertyWidget.h.
