property-widget for creating selection queries. More...
#include <pqSelectionQueryPropertyWidget.h>
Signals | |
void | queryChanged () |
void | viewChanged (pqView *view) |
This signal is emitted when the current view changes. More... | |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
pqSelectionQueryPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr) | |
~pqSelectionQueryPropertyWidget () override | |
void | setQuery (const QString &) |
Get/Set the query string. More... | |
const QString & | query () const |
pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqPropertyWidget () override | |
virtual void | apply () |
virtual void | reset () |
virtual void | updateWidget (bool showing_advanced_properties) |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual char * | panelVisibility () const |
Forward calls to vtkSMProperty. More... | |
virtual void | setPanelVisibility (const char *vis) |
virtual bool | isSingleRowItem () const |
Determines if the PropertyWidget must be constructed using a single row. More... | |
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
Provides access to the decorators for this widget. More... | |
void | setProperty (vtkSMProperty *property) |
virtual void | select () |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More... | |
virtual void | selectPort (int portIndex) |
virtual void | deselect () |
bool | isSelected () const |
Properties | |
QString | query |
Friends | |
class | pqInternals |
class | pqValueWidget |
class | pqQueryWidget |
virtual void | setView (pqView *) |
called to set the active view. More... | |
template<class T > | |
static QString | getXMLName (T *object) |
Description: This static utility method returns the XML name for an object as a QString. More... | |
static QString | getTooltip (vtkSMProperty *property) |
Returns the tooltip to use for the property. More... | |
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
Helper method to return value from WidgetHeight XML hint, if any. More... | |
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
Parse a XML element as a list of label to use for this widget. More... | |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More... | |
void | addDecorator (pqPropertyWidgetDecorator *) |
Register a decorator. More... | |
void | removeDecorator (pqPropertyWidgetDecorator *) |
Unregisters a decorator. More... | |
pqPropertyLinks & | links () |
Provides access to the pqPropertyLinks instance. More... | |
pqSelectionQueryPropertyWidget is a pqPropertyWidget subclass that can be used for a property accepting a string representing a selection query. The widget allows users to build selection queries easily.
To use this widget on a property with vtkSMSelectionQueryDomain, set the panel_widget
to selection_query
Currently, this widget can faithfully present GUI for query strings that follow a specific form that is generated by this property itself. Any other forms, though valid queries, will not be represented properly in the GUI.
Definition at line 30 of file pqSelectionQueryPropertyWidget.h.
pqSelectionQueryPropertyWidget::pqSelectionQueryPropertyWidget | ( | vtkSMProxy * | proxy, |
vtkSMProperty * | property, | ||
QWidget * | parent = nullptr |
void pqSelectionQueryPropertyWidget::setQuery | ( | const QString & | ) |
const QString& pqSelectionQueryPropertyWidget::query | ( | ) | const |
signal |
friend |
Definition at line 60 of file pqSelectionQueryPropertyWidget.h.
friend |
Definition at line 63 of file pqSelectionQueryPropertyWidget.h.
friend |
Definition at line 64 of file pqSelectionQueryPropertyWidget.h.
readwrite |
Definition at line 35 of file pqSelectionQueryPropertyWidget.h.
