pqStandardPropertyWidgetInterface provides a concrete implementation of pqPropertyWidget used by ParaView application. More...
#include <pqStandardPropertyWidgetInterface.h>
pqStandardPropertyWidgetInterface (QObject *p=nullptr) | |
~pqStandardPropertyWidgetInterface () override | |
pqPropertyWidget * | createWidgetForProperty (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parentWidget) override |
Given a proxy and its property, create a widget for the same, if possible. More... | |
pqPropertyWidget * | createWidgetForPropertyGroup (vtkSMProxy *proxy, vtkSMPropertyGroup *group, QWidget *parentWidget) override |
Given a proxy and its property group, create a widget for the same, of possible. More... | |
pqPropertyWidgetDecorator * | createWidgetDecorator (const QString &type, vtkPVXMLElement *config, pqPropertyWidget *widget) override |
Given the type of the decorator and the pqPropertyWidget that needs to be decorated, create the pqPropertyWidgetDecorator instance, if possible. More... | |
void | createDefaultWidgetDecorators (pqPropertyWidget *widget) override |
Create all default decorators for a specific widget. More... | |
virtual | ~pqPropertyWidgetInterface () |
It adds logic to create some of the custom widgets and decorators used by ParaView's Properties Panel.
Definition at line 15 of file pqStandardPropertyWidgetInterface.h.
pqStandardPropertyWidgetInterface::pqStandardPropertyWidgetInterface | ( | QObject * | p = nullptr | ) |
For unsupported/unknown proxies/properties, implementations should simply return nullptr without raising any errors (or messages). Supported types are:
calculator
: pqCalculatorWidget camera_manipulator
: pqCameraManipulatorWidget color_palette_selector
: pqColorPaletteSelectorWidget color_selector
: pqColorSelectorPropertyWidget color_selector_with_palette
: pqColorSelectorPropertyWidget with palette menu command_button
: pqCommandButtonPropertyWidget display_representation_selector
: pqDisplayRepresentationPropertyWidget double_range
: pqDoubleRangeSliderPropertyWidget filename_widget:
pqFileNamePropertyWidget glyph_scale_factor:
pqGlyphScaleFactorPropertyWidget image_compressor_config
: pqImageCompressorWidget index_selection
: pqIndexSelectionWidget input_selector
: pqInputSelectorWidget int_mask:
pqIntMaskPropertyWidget list
: pqListPropertyWidget proxy_editor:
pqProxyEditorPropertyWidget texture_selector
: pqTextureSelectorPropertyWidget transfer_function_editor
: pqTransferFunctionWidgetPropertyWidget viewtype_selector:
pqViewTypePropertyWidget language_selector:
pqLanguageChooserWidget view_resolution:
pqViewResolutionPropertyWidget pause_livesource:
pqPauseLiveSourcePropertyWidget data_assembly_editor:
pqDataAssemblyPropertyWidget selection_query
: pqSelectionQueryPropertyWidget file_list
: pqFileListPropertyWidget xy_chart_bounds
: pqXYChartViewBoundsPropertyWidget Reimplemented from pqPropertyWidgetInterface.
For unsupported/unknown proxies/property-groups, implementations should simply return nullptr without raising any errors (or messages). Supported types are:
AnnotationsEditor
: pqColorAnnotationsPropertyWidget ArrayStatus
: pqArrayStatusPropertyWidget BackgroundEditor
: pqBackgroundPropertyWidget ColorEditor
: pqColorEditorPropertyWidget ColorOpacityEditor
: pqColorOpacityEditorWidget FontEditor
: pqFontPropertyWidget SeriesEditor
: pqSeriesEditorPropertyWidget InteractivePlane
: pqDisplaySizedImplicitPlanePropertyWidget InteractivePlane2
: pqImplicitPlanePropertyWidget InteractiveBox:
pqBoxPropertyWidget InteractiveHandle:
pqHandlePropertyWidget InteractiveLine:
pqLinePropertyWidget InteractiveSpline:
pqSplinePropertyWidget InteractiveSphere:
pqSpherePropertyWidget InteractivePolyLine:
pqSplinePropertyWidget (with mode==POLYLINE) InteractiveCylinder:
pqCylinderPropertyWidget YoungsMaterial:
pqYoungsMaterialPropertyWidget OMETransferFunctions
: pqOMETransferFunctionsPropertyWidget PropertyCollection
: pqPropertyCollectionWidget DataAssemblyEditor:
pqDataAssemblyPropertyWidget CheckableProperty
: pqCheckableProperty EqualizerPropertyWidget
: pqEqualizerPropertyWidget MetaDataPropertyWidget
: pqMetaDataPropertyWidget Reimplemented from pqPropertyWidgetInterface.
For unsupported/unknown, implementations should simply return nullptr without raising any errors (or messages). Supported types are:
CTHArraySelectionDecorator
: pqCTHArraySelectionDecorator EnableWidgetDecorator
: pqEnableWidgetDecorator ShowWidgetDecorator
: pqShowWidgetDecorator InputDataTypeDecorator
: pqInputDataTypeDecorator GenericDecorator:
pqGenericPropertyWidgetDecorator OSPRayHidingDecorator:
pqOSPRayHidingDecorator MultiComponentsDecorator:
pqMultiComponentsDecorator CompositeDecorator:
pqCompositePropertyWidgetDecorator SessionTypeDecorator:
pqSessionTypeDecorator Reimplemented from pqPropertyWidgetInterface.
Created decorators are:
AnimationShortcutDecorator
: pqAnimationShortcutDecorator Reimplemented from pqPropertyWidgetInterface.
