widget for view resolution. More...
#include <pqViewResolutionPropertyWidget.h>
Signals | |
void | highlightResetButton () |
internal signals used to highlight (or not) the "reset-to-domain" button. More... | |
void | clearHighlight () |
void | viewChanged (pqView *view) |
This signal is emitted when the current view changes. More... | |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
pqViewResolutionPropertyWidget (vtkSMProxy *proxy, vtkSMProperty *smproperty, QWidget *parent=nullptr) | |
~pqViewResolutionPropertyWidget () override | |
void | apply () override |
Overridden to clear the state for the highlight state for "reset-to-domain" button. More... | |
void | reset () override |
pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqPropertyWidget () override | |
virtual void | updateWidget (bool showing_advanced_properties) |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual char * | panelVisibility () const |
Forward calls to vtkSMProperty. More... | |
virtual void | setPanelVisibility (const char *vis) |
virtual bool | isSingleRowItem () const |
Determines if the PropertyWidget must be constructed using a single row. More... | |
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
Provides access to the decorators for this widget. More... | |
void | setProperty (vtkSMProperty *property) |
virtual void | select () |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More... | |
virtual void | selectPort (int portIndex) |
virtual void | deselect () |
bool | isSelected () const |
virtual void | setView (pqView *) |
called to set the active view. More... | |
template<class T > | |
static QString | getXMLName (T *object) |
Description: This static utility method returns the XML name for an object as a QString. More... | |
static QString | getTooltip (vtkSMProperty *property) |
Returns the tooltip to use for the property. More... | |
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
Helper method to return value from WidgetHeight XML hint, if any. More... | |
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
Parse a XML element as a list of label to use for this widget. More... | |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More... | |
void | addDecorator (pqPropertyWidgetDecorator *) |
Register a decorator. More... | |
void | removeDecorator (pqPropertyWidgetDecorator *) |
Unregisters a decorator. More... | |
pqPropertyLinks & | links () |
Provides access to the pqPropertyLinks instance. More... | |
pqViewResolutionPropertyWidget is desined to be used with properties that allow users to set resolution for things like views, images, movies etc. It provides UI elements to lock aspect ratio, scale size up or down, and reset to default.
This widget works with any vtkSMIntVectorProperty with 2 elements interpreted as (width, height).
As specified in pqStandardPropertyWidgetInterface, to use this widget for a property you can use panel_widget="view_resolution"
attribute in ServerManager XML.
Definition at line 27 of file pqViewResolutionPropertyWidget.h.
pqViewResolutionPropertyWidget::pqViewResolutionPropertyWidget | ( | vtkSMProxy * | proxy, |
vtkSMProperty * | smproperty, | ||
QWidget * | parent = nullptr |
The implementation simply fires clearHighlight
signal.
Reimplemented from pqPropertyWidget.
signal.
signal |
signal |
