This is a custom widget for YoungsMaterialInterface filter. More...
#include <pqYoungsMaterialPropertyWidget.h>
Signals | |
void | orderingArraysChanged () |
Emitted when the ordering arrays change, linked ot the SMProperty. More... | |
void | normalArraysChanged () |
Emitted when the normal arrays change, linked ot the SMProperty. More... | |
void | viewChanged (pqView *view) |
This signal is emitted when the current view changes. More... | |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
pqYoungsMaterialPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *group, QWidget *parent=nullptr) | |
~pqYoungsMaterialPropertyWidget () override | |
void | setOrderingArrays (const QList< QVariant > &) |
Get/Set the ordering arrays, linked to the SMProperty. More... | |
QList< QVariant > | orderingArrays () const |
void | setNormalArrays (const QList< QVariant > &) |
Get/Set the normal arrays, linked to the SMProperty. More... | |
QList< QVariant > | normalArrays () const |
pqStringVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqStringVectorPropertyWidget () override | |
pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqPropertyWidget () override | |
virtual void | apply () |
virtual void | reset () |
virtual void | updateWidget (bool showing_advanced_properties) |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual char * | panelVisibility () const |
Forward calls to vtkSMProperty. More... | |
virtual void | setPanelVisibility (const char *vis) |
virtual bool | isSingleRowItem () const |
Determines if the PropertyWidget must be constructed using a single row. More... | |
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
Provides access to the decorators for this widget. More... | |
void | setProperty (vtkSMProperty *property) |
virtual void | select () |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More... | |
virtual void | selectPort (int portIndex) |
virtual void | deselect () |
bool | isSelected () const |
Protected Slots | |
void | onOrderingArraysChanged () |
Called when the ordering array is changed. More... | |
void | onNormalArraysChanged () |
Called when the normal array is changed. More... | |
void | updateComboBoxes () |
Called to initialize/update the combobox according to the current item. More... | |
QStandardItem * | currentItem () |
Recover the currently selecticted item in the VolumeFractionArrays widget. More... | |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More... | |
void | addDecorator (pqPropertyWidgetDecorator *) |
Register a decorator. More... | |
void | removeDecorator (pqPropertyWidgetDecorator *) |
Unregisters a decorator. More... | |
pqPropertyLinks & | links () |
Provides access to the pqPropertyLinks instance. More... | |
Properties | |
QList< QVariant > | orderingArrays |
QList< QVariant > | normalArrays |
virtual void | setView (pqView *) |
called to set the active view. More... | |
static pqPropertyWidget * | createWidget (vtkSMStringVectorProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent=nullptr) |
Factory method to instantiate a hard-coded type of pqPropertyWidget subclass for t he vtkSMStringVectorProperty. More... | |
static void | processFileChooserHints (vtkPVXMLElement *hints, bool &directoryMode, bool &anyFile, QString &filter, bool &browseLocalFileSystem) |
Method to process file-choice related hints. More... | |
template<class T > | |
static QString | getXMLName (T *object) |
Description: This static utility method returns the XML name for an object as a QString. More... | |
static QString | getTooltip (vtkSMProperty *property) |
Returns the tooltip to use for the property. More... | |
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
Helper method to return value from WidgetHeight XML hint, if any. More... | |
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
Parse a XML element as a list of label to use for this widget. More... | |
We use a custom widget since this filter has unusual requirements when it comes to setting OrderingArrays and NormalArrays properties.
Definition at line 20 of file pqYoungsMaterialPropertyWidget.h.
pqYoungsMaterialPropertyWidget::pqYoungsMaterialPropertyWidget | ( | vtkSMProxy * | proxy, |
vtkSMPropertyGroup * | group, | ||
QWidget * | parent = nullptr |
void pqYoungsMaterialPropertyWidget::setOrderingArrays | ( | const QList< QVariant > & | ) |
QList<QVariant> pqYoungsMaterialPropertyWidget::orderingArrays | ( | ) | const |
void pqYoungsMaterialPropertyWidget::setNormalArrays | ( | const QList< QVariant > & | ) |
QList<QVariant> pqYoungsMaterialPropertyWidget::normalArrays | ( | ) | const |
signal |
signal |
protectedslot |
protectedslot |
protectedslot |
readwrite |
Definition at line 26 of file pqYoungsMaterialPropertyWidget.h.
readwrite |
