13 #ifndef vtkSMDoubleVectorProperty_h 14 #define vtkSMDoubleVectorProperty_h 44 int SetElement(
unsigned int idx,
double value);
54 int SetElements(
const double* values);
55 int SetElements(
const double* values,
unsigned int numValues);
56 double* GetElements();
63 int SetUncheckedElements(
64 int SetUncheckedElements(
73 int SetElements1(
double value0);
81 int SetElements2(
double value0,
double value1);
89 int SetElements3(
double value0,
double value1,
double value2);
97 int SetElements4(
double value0,
double value1,
double value2,
double value3);
102 int AppendElements(
107 int AppendUncheckedElements(
112 double GetElement(
unsigned int idx);
127 double GetUncheckedElement(
unsigned int idx);
134 void SetUncheckedElement(
unsigned int idx,
double value);
149 vtkGetMacro(ArgumentIsArray,
int);
150 vtkSetMacro(ArgumentIsArray,
int);
209 vtkInternals* Internals;
virtual void SaveStateValues(vtkPVXMLElement *propertyElement)
This method must be overridden by concrete class in order to save the real property data...
virtual void WriteTo(vtkSMMessage *msg)
Let the property write its content into the stream.
virtual void SetNumberOfUncheckedElements(unsigned int num)=0
API for setting unchecked element values.
void Copy(vtkSMProperty *src) override
Copy all property values.
virtual void SetNumberOfElements(unsigned int num)=0
Sets the size of the vector.
abstract superclass for all vector properties
static vtkSMProperty * New()
implementation for View that includes render window and renderers.
virtual unsigned int GetNumberOfUncheckedElements()=0
property representing a vector of doubles
virtual void ReadFrom(const vtkSMMessage *, int vtkNotUsed(message_offset), vtkSMProxyLocator *)
void ClearUncheckedElements() override=0
virtual void ResetToXMLDefaults()
For properties that support specifying defaults in XML configuration, this method will reset the prop...
virtual int LoadState(vtkPVXMLElement *element, vtkSMProxyLocator *loader)
Updates state from an XML element.
int ReadXMLAttributes(vtkSMProxy *parent, vtkPVXMLElement *element) override
virtual bool IsValueDefault()
virtual unsigned int GetNumberOfElements()=0
Returns the size of the vector.
Class used to retrieve a given message state based on its GlobalID.
