cue used for parameter animation by the comparative view. More...
#include <vtkSMComparativeAnimationCueProxy.h>
| typedef vtkSMProxy | Superclass |
Public Types inherited from vtkSMProxy | |
| enum | ResetPropertiesMode { DEFAULT = 0, ONLY_XML = 1, ONLY_DOMAIN = 2 } |
| enum | { COPY_PROXY_PROPERTY_VALUES_BY_REFERENCE = 0, COPY_PROXY_PROPERTY_VALUES_BY_CLONING } |
| Flags used for the proxyPropertyCopyFlag argument to the Copy method. More... | |
| vtkPVXMLElement * | SaveXMLState (vtkPVXMLElement *root) override |
| Saves the state of the proxy. More... | |
| vtkPVXMLElement * | SaveXMLState (vtkPVXMLElement *root, vtkSMPropertyIterator *iter) override |
| The iterator is use to filter the property available on the given proxy. More... | |
| int | LoadXMLState (vtkPVXMLElement *element, vtkSMProxyLocator *locator) override |
| Loads the proxy state from the XML element. More... | |
| void | UpdateXRange (int y, double minx, double maxx) |
| Methods simply forwarded to vtkPVComparativeAnimationCue. More... | |
| void | UpdateYRange (int x, double miny, double maxy) |
| void | UpdateWholeRange (double mint, double maxt) |
| void | UpdateValue (int x, int y, double value) |
| void | UpdateXRange (int y, double *minx, double *maxx, unsigned int numvalues) |
| void | UpdateYRange (int x, double *minx, double *maxx, unsigned int numvalues) |
| void | UpdateWholeRange (double *mint, double *maxt, unsigned int numValues) |
| void | UpdateWholeRange (double *mint, double *maxt, unsigned int numValues, bool vertical_first) |
| void | UpdateValue (int x, int y, double *value, unsigned int numValues) |
| double * | GetValues (int x, int y, int dx, int dy, unsigned int &numValues) |
| double | GetValue (int x, int y, int dx, int dy) |
| void | UpdateAnimatedValue (int x, int y, int dx, int dy) |
Public Member Functions inherited from vtkSMProxy | |
| Retrieve an annotation with a given key. More... | |
| Remove a given annotation based on its key to the proxy. More... | |
| Remove all proxy annotations. More... | |
| Return true if a given annotation exists. More... | |
| Return the number of available annotations. More... | |
| Return the nth key of the available annotations. More... | |
| Return the property with the given name. More... | |
| Return a property of the given name from self or one of the sub-proxies. More... | |
| Given a property pointer, returns the name that was used to add it to the proxy. More... | |
| Update the VTK object on the server by pushing the values of all modified properties (un-modified properties are ignored). More... | |
| Recreate the VTK object for this proxy. More... | |
| Convenience method equivalent to UpdateProperty(name, 1). More... | |
| Returns a new (initialized) iterator of the properties. More... | |
| Returns the number of consumers. More... | |
| Returns the consumer of given index. More... | |
| Returns the corresponding property of the consumer of given index. More... | |
| Returns the number of proxies this proxy depends on (uses or is connected to through the pipeline). More... | |
| Returns a proxy this proxy depends on, given index. More... | |
| Returns the property holding a producer proxy given an index. More... | |
| Updates all property information by calling UpdateInformation() and populating the values. More... | |
| Similar to UpdatePropertyInformation() but updates only the given property. More... | |
| Marks all properties as modified. More... | |
| Use this method to set all properties on this proxy to their default values. More... | |
| Use this method to set all properties on this proxy to their default domains. More... | |
| Use this method to set all properties on this proxy to their default domain or values. More... | |
| Calls MarkDirty() and invokes ModifiedEvent. More... | |
| bool | IsDeprecated () |
| Returns true if the proxy has a deprecation tag. More... | |
| Given a source proxy, makes this proxy point to the same server-side object (with a new id). More... | |
| Dirty means this algorithm will execute during next update. More... | |
| Returns the client side object associated with the VTKObjectID (if any). More... | |
| This method call UpdateVTKObjects on the current pipeline by starting at the sources. More... | |
| bool | GetIsSubProxy () |
| A proxy instance can be a sub-proxy for some other proxy. More... | |
| If this instance is a sub-proxy, this method will return the proxy of which this instance is an immediate sub-proxy. More... | |
| Call GetParentProxy() recursively till a proxy that is not a subproxy of any other proxy is found. More... | |
| This method return the full object state that can be used to create that object from scratch. More... | |
| This method is used to initialise the object to the given state If the definitionOnly Flag is set to True the proxy won't load the properties values and just setup the new proxy hierarchy with all subproxy globalID set. More... | |
| Returns the number of property groups that the proxy contains. More... | |
| Return the property names that have values different from the otherProxy argument. More... | |
| Update the value of one property (pushed to the server) if it is modified. More... | |
| Returns the type of object managed by the proxy. More... | |
| the type of object created by the proxy. More... | |
| Copies values of all the properties and sub-proxies from src. More... | |
| Returns if the VTK objects for this proxy have been created. More... | |
| Gathers information about this proxy. More... | |
| Log name is a name for this proxy that will be used when logging status messages. More... | |
| bool | HasGlobalID () |
| bool | IsPrototype () |
| static vtkSMComparativeAnimationCueProxy * | New () |
| static vtkSMComparativeAnimationCueProxy * | SafeDownCast (vtkObject *o) |
Static Public Member Functions inherited from vtkSMProxy | |
| static vtkSMProxy * | New () |
| static vtkSMProxy * | SafeDownCast (vtkObject *o) |
| vtkSMComparativeAnimationCueProxy () | |
| ~vtkSMComparativeAnimationCueProxy () override | |
| void | CreateVTKObjects () override |
| Given a class name (by setting VTKClassName) and server ids (by setting ServerIDs), this methods instantiates the objects on the server(s) More... | |
| vtkPVComparativeAnimationCue * | GetComparativeAnimationCue () |
Protected Member Functions inherited from vtkSMProxy | |
| vtkSMProxy () | |
| ~vtkSMProxy () override | |
| Invoke that takes a vtkClientServerStream as the argument. More... | |
| Add a property with the given key (name). More... | |
MarkConsumersAsDirty calls this method on each consumer, instead of directly calling MarkDirty on the consumer. More... | |
| This method is called by vtkSMRepresentationProxy whenever the time request for the pipeline may have potentially changed. More... | |
| Cleanup code. More... | |
| Note on property modified flags: The modified flag of each property associated with a proxy is stored in the proxy object instead of in the property itself. More... | |
| Add a sub-proxy. More... | |
| Remove a sub-proxy. More... | |
| Returns a sub-proxy. More... | |
| Returns the name used to store sub-proxy. More... | |
| Returns the number of sub-proxies. More... | |
| Called by a proxy property, this adds the property,proxy pair to the list of consumers. More... | |
| Remove the property,proxy pair from the list of consumers. More... | |
| Remove all consumers. More... | |
| Called by an proxy/input property to add property, proxy pair to the list of producers. More... | |
| Remove the property,proxy pair from the list of producers. More... | |
| This method is called after the algorithm(s) (if any) associated with this proxy execute. More... | |
This is called by PostUpdateData to only update state for this proxy without iterative over producers. More... | |
| If a proxy need to ensure a plugin is loaded, make sure it is. More... | |
| This method simply iterates over subproxies and calls UpdatePipelineInformation() on them. More... | |
| Links properties such that when inputProperty's checked or unchecked values are changed, the outputProperty's corresponding values are also changed. More... | |
| Parses the XML to create a new property group. More... | |
| Adds a property groups. More... | |
| Expose a subproxy property from the base proxy. More... | |
| Handle events fired by subproxies. More... | |
| Called to update the property information on the property. More... | |
| vtkSMProxy tracks state of properties on this proxy in an internal State object. More... | |
Internal method used by SetLogName More... | |
| Indicates if any properties are modified. More... | |
| Set the "EnsurePluginLoaded" XML element that is used in LoadPluginIfEnsured. More... | |
| vtkSMProxy (const vtkSMProxy &)=delete | |
| Get the last result. More... | |
| Creates a new property and initializes it by calling ReadXMLAttributes() with the right XML element. More... | |
| Read attributes from an XML element. More... | |
| SIClassName identifies the classname for the helper on the server side. More... | |
| vtkSMRemoteObject () | |
| Destructor. More... | |
| vtkSMSessionObject () | |
| vtkSMObject () | |
Friends | |
| class | vtkSMComparativeAnimationCueUndoElement |
vtkSMComparativeAnimationCueProxy is a animation cue used for parameter animation by the vtkSMComparativeViewProxy. It provides a non-conventional API i.e. without using properties to allow the user to setup parameter values over the comparative grid.
Definition at line 22 of file vtkSMComparativeAnimationCueProxy.h.
Definition at line 26 of file vtkSMComparativeAnimationCueProxy.h.
Any of these methods changing the state of the proxy, also call this->MarkModified(this).
| void vtkSMComparativeAnimationCueProxy::UpdateXRange | ( | int | y, |
| double * | minx, | ||
| double * | maxx, | ||
| unsigned int | numvalues | ||
| void vtkSMComparativeAnimationCueProxy::UpdateYRange | ( | int | x, |
| void vtkSMComparativeAnimationCueProxy::UpdateWholeRange | ( | double * | mint, |
| double * | maxt, | ||
| unsigned int | numValues | ||
| unsigned int | numValues, | ||
| bool | vertical_first | ||
| void vtkSMComparativeAnimationCueProxy::UpdateValue | ( | int | x, |
| int | y, | ||
| double * | value, | ||
| double* vtkSMComparativeAnimationCueProxy::GetValues | ( | int | x, |
| int | y, | ||
| int | dx, | ||
| int | dy, | ||
| unsigned int & | numValues | ||
inlineoverridevirtual |
This state can be reloaded to create a new proxy that is identical the present state of this proxy. The resulting proxy's XML hieratchy is returned, in addition if the root argument is not nullptr then it's also inserted as a nested element. This call saves all a proxy's properties, including exposed properties and sub-proxies. More control is provided by the following overload.
Definition at line 57 of file vtkSMComparativeAnimationCueProxy.h.
Returns 0 on failure. locator is used to locate other proxies that may be referred to in the state XML (which happens in case of properties of type vtkSMProxyProperty or subclasses). If locator is nullptr, then such properties are left unchanged.
overrideprotectedvirtual |
friend |
Definition at line 88 of file vtkSMComparativeAnimationCueProxy.h.
1.8.13 on Sun Dec 14 2025
