vtkSMGL2PSExporterProxy Class Reference
Proxy for vtkPVGL2PSExporter. More...
#include <vtkSMGL2PSExporterProxy.h>
Inheritance diagram for vtkSMGL2PSExporterProxy:
Collaboration diagram for vtkSMGL2PSExporterProxy:
typedef vtkSMRenderViewExporterProxy Superclass
- Public Types inherited from vtkSMRenderViewExporterProxy
typedef vtkSMExporterProxy Superclass
- Public Types inherited from vtkSMExporterProxy
typedef vtkSMProxy Superclass
bool CanExport (vtkSMProxy *) override
 Returns if the view can be exported. More...
void Write () override
 Export the current view. More...
 See superclass documentation for description. More...
- Public Member Functions inherited from vtkSMRenderViewExporterProxy
 Exports the view. More...
void SetView (vtkSMViewProxy *view) override
 Set the view used for export, and update all domains based on prop extraction using the view. More...
- Public Member Functions inherited from vtkSMExporterProxy
virtual vtkSMViewProxyGetView ()
 Set the view proxy to export. More...
const std::vector< std::string > & GetFileExtensions () const
 Returns the suggested file extensions for this exporter. More...
void RemoveAllAnnotations ()
int GetNumberOfAnnotations ()
bool IsDeprecated ()
bool GetIsSubProxy ()
vtkSMProxyGetParentProxy ()
bool GetPropertiesModified ()
virtual char * GetXMLName ()
virtual char * GetXMLGroup ()
virtual char * GetXMLLabel ()
void Copy (vtkSMProxy *src)
void PrototypeOn () override
void PrototypeOff () override
virtual char * GetLogName ()
bool HasGlobalID ()
bool IsPrototype ()
static vtkSMGL2PSExporterProxyNew ()
static vtkSMGL2PSExporterProxySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMRenderViewExporterProxy
static vtkSMRenderViewExporterProxyNew ()
static vtkSMRenderViewExporterProxySafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkSMExporterProxy
static vtkSMExporterProxySafeDownCast (vtkObject *o)
static vtkSMProxyNew ()
static vtkSMObjectNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkSMGL2PSExporterProxy ()
 ~vtkSMGL2PSExporterProxy () override
- Protected Member Functions inherited from vtkSMRenderViewExporterProxy
 vtkSMRenderViewExporterProxy ()
 ~vtkSMRenderViewExporterProxy () override
- Protected Member Functions inherited from vtkSMExporterProxy
 vtkSMExporterProxy ()
 ~vtkSMExporterProxy () override
 vtkSMProxy ()
 ~vtkSMProxy () override
void MarkInputsAsDirty ()
 Cleanup code. More...
 Add a sub-proxy. More...
 Remove a sub-proxy. More...
 Returns a sub-proxy. More...
 Remove all consumers. More...
bool WarnIfDeprecated ()
bool LoadPluginIfEnsured ()
bool ArePropertiesModified ()
 Get the last result. More...
 vtkSMRemoteObject ()
 Default constructor. More...
 Destructor. More...
 vtkSMSessionObject ()
 vtkSMObject ()
 ~vtkSMObject () override
enum  { None, ContextView, RenderView }
 Type of view that this exporter is configured to export. More...
int ViewType
- Protected Attributes inherited from vtkSMExporterProxy
vtkSMViewProxyView
std::vector< std::stringFileExtensions
bool NeedsUpdate
char * VTKClassName
char * XMLGroup
char * XMLName
char * XMLLabel
char * XMLSubProxyName
int ObjectsCreated
int DoNotUpdateImmediately
int DoNotModifyProperty
int InUpdateVTKObjects
bool PropertiesModified
vtkPVXMLElementXMLElement
vtkSMMessageState
int InMarkModified
vtkSMProxyInternalsInternals
char * SIClassName
vtkTypeUInt32 GlobalID
vtkTypeUInt32 Location
bool Prototype
bool ClientOnlyLocationFlag
Definition at line 16 of file vtkSMGL2PSExporterProxy.h.
Definition at line 20 of file vtkSMGL2PSExporterProxy.h.
◆ anonymous enum
anonymous enum
Enumerator
None
ContextView
RenderView
Definition at line 48 of file vtkSMGL2PSExporterProxy.h.
◆ vtkSMGL2PSExporterProxy()
vtkSMGL2PSExporterProxy::vtkSMGL2PSExporterProxy ( )
◆ ~vtkSMGL2PSExporterProxy()
vtkSMGL2PSExporterProxy::~vtkSMGL2PSExporterProxy ( )
static vtkSMGL2PSExporterProxy* vtkSMGL2PSExporterProxy::New ( )
virtual const char* vtkSMGL2PSExporterProxy::GetClassName ( )
Reimplemented from vtkSMRenderViewExporterProxy.
static int vtkSMGL2PSExporterProxy::IsTypeOf ( const char *  type)
virtual int vtkSMGL2PSExporterProxy::IsA ( const char *  type)
static vtkSMGL2PSExporterProxy* vtkSMGL2PSExporterProxy::SafeDownCast ( vtkObject o)
void vtkSMGL2PSExporterProxy::PrintSelf ( ostream &  os,
Reimplemented from vtkSMExporterProxy.
◆ CanExport()
bool vtkSMGL2PSExporterProxy::CanExport ( vtkSMProxy )
Default implementation return true if the view is a render view or a context view.
Implements vtkSMExporterProxy.
◆ Write()
void vtkSMGL2PSExporterProxy::Write ( )
◆ ReadXMLAttributes()
int vtkSMGL2PSExporterProxy::ReadXMLAttributes ( vtkSMSessionProxyManager pm,
vtkPVXMLElement element
◆ ViewType
int vtkSMGL2PSExporterProxy::ViewType
Definition at line 54 of file vtkSMGL2PSExporterProxy.h.
