void | Write () override |
| Exports the view. More...
void | SetView (vtkSMViewProxy *view) override |
| Set the view used for export, and update all domains based on prop extraction using the view. More...
bool | CanExport (vtkSMProxy *) override |
| Returns if the view can be exported. More...
virtual vtkSMViewProxy * | GetView () |
| Set the view proxy to export. More...
const std::vector< std::string > & | GetFileExtensions () const |
| Returns the suggested file extensions for this exporter. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
