const char * | GetRepresentationType (vtkSMSourceProxy *producer, int outputPort) override |
| Overridden to forward the call to the internal root view proxy. More...
vtkSMRepresentationProxy * | CreateDefaultRepresentation (vtkSMProxy *proxy, int outputPort) override |
| Overridden to set initial default slices when a representation is created. More...
vtkSMRepresentationProxy * | Pick (int x, int y) |
| Convenience method to pick a location. More...
vtkSMRepresentationProxy * | PickBlock (int x, int y, unsigned int &flatIndex, int &rank) |
| Convenience method to pick a block in a multi-block data set. More...
bool | ConvertDisplayToPointOnSurface (const int display_position[2], double world_position[3], double world_normal[3], bool snapOnMeshPoint=false) |
| Given a location is display coordinates (pixels), tries to compute and return the world location and normal on a surface, if possible. More...
virtual bool | IsSelectionAvailable () |
| Checks if color depth is sufficient to support selection. More...
void | SynchronizeGeometryBounds () |
| Call SynchronizeGeometryBounds server side. More...
virtual void | ZoomTo (vtkSMProxy *representation, bool closest=false, double offsetRatio=0.9) |
| Convenience method for zooming to a representation. More...
void | SetupInteractor (vtkRenderWindowInteractor *iren) override |
| A client process need to set the interactor to enable interactivity. More...
vtkRenderWindowInteractor * | GetInteractor () override |
| Returns the interactor. More...
vtkRenderer * | GetRenderer () |
| Returns the client-side renderer (composited or 3D). More...
void | UpdateVTKObjects () override |
| Filter changes to the OSPRay rendering method, to transfer the pathtracing materials from client to server only when they are acutally needed. More...
void | SynchronizeCameraProperties () |
| This method calls UpdateInformation on the Camera Proxy and sets the Camera properties according to the info properties. More...
virtual bool | LastRenderWasInteractive () |
| Returns true if the most recent render indeed employed low-res rendering. More...
void | Update () override |
| Called vtkPVView::Update on the server-side. More...
bool | GetNeedsUpdate () override |
| We override that method to handle LOD and non-LOD NeedsUpdate in transparent manner. More...
bool | StreamingUpdate (bool render_if_needed) |
| Called to render a streaming pass. More...
| Overridden to check through the various representations that this view can create. More...
vtkRenderWindow * | GetRenderWindow () override |
| Returns the render window used by this view. More...
vtkSMViewProxyInteractorHelper * | GetInteractorHelper () |
| Provides access to the vtkSMViewProxyInteractorHelper object that handles the interaction/view sync. More...
vtkFloatArray * | CaptureDepthBuffer () |
| Access to the Z buffer. More...
virtual const char * | GetSelectionRepresentationProxyName () |
| Get the SelectionRepresentation proxy name. More...
virtual void | CopySelectionRepresentationProperties (vtkSMProxy *vtkNotUsed(fromSelectionRep), vtkSMProxy *vtkNotUsed(toSelectionRep)) |
| Function to copy selection representation properties. More...
void | ComputeVisibleBounds (vtkSMProxy *representation, double *bounds) |
| Compute the bounds of the visible data on the given representation. More...
bool | ClearSelectionCache (bool force=false) |
| Tries to clear the selection cache (if needed). More...
void | SetEnableSynchronizableActors (bool) |
| Turn on/off synchronizable actors. More...
bool | GetEnableSynchronizableActors () |
bool | GetIsInCAVE () |
| Get whether system is in CAVE mode. More...
int | GetNumberOfDisplays () |
| Get the number of remote displays. More...
double | GetEyeSeparation () |
| Get the remotely configured eye separation. More...
bool | GetShowBorders () |
| Get whether or not remote displays show borders. More...
bool | GetFullScreen () |
| Get whether or not remote displays are fullscreen. More...
vtkTuple< int, 4 > | GetGeometry (int index) |
| Get the geometry of the screen at the given index, as (x, y, width, height). More...
bool | GetHasCorners (int index) |
| Get whether or not the given display has screen corner set. More...
vtkTuple< double, 3 > | GetLowerLeft (int index) |
| Get the lower left corner of the screen at the given index, as (x, y, z). More...
vtkTuple< double, 3 > | GetLowerRight (int index) |
| Get the lower right corner of the screen at the given index, as (x, y, z). More...
vtkTuple< double, 3 > | GetUpperRight (int index) |
| Get the upper right corner of the screen at the given index, as (x, y, z). More...
bool | SelectSurfaceCells (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool select_blocks=false, const char *arrayName=nullptr) |
| Makes a new selection source proxy. More...
bool | SelectSurfacePoints (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool select_blocks=false, const char *arrayName=nullptr) |
bool | SelectFrustumCells (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false) |
bool | SelectFrustumPoints (const int region[4], vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false) |
bool | SelectPolygonPoints (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool selectBlocks=false) |
bool | SelectPolygonCells (vtkIntArray *polygon, vtkCollection *selectedRepresentations, vtkCollection *selectionSources, bool multiple_selections=false, int modifier=0, bool selectBlocks=false) |
bool | ComputeVisibleScalarRange (const int region[4], int fieldAssociation, const char *scalarName, int component, double range[]) |
| Returns the range for visible elements in the current view. More...
bool | ComputeVisibleScalarRange (int fieldAssociation, const char *scalarName, int component, double range[]) |
void | ResetCamera (bool closest=false, double offsetRatio=0.9) |
| For backwards compatibility in Python scripts. More...
void | ResetCamera (double bounds[6], bool closest=false, double offsetRatio=0.9) |
void | ResetCamera (double xmin, double xmax, double ymin, double ymax, double zmin, double zmax, bool closest=false, double offsetRatio=0.9) |
virtual const char * | IsSelectVisibleCellsAvailable () |
| Similar to IsSelectionAvailable(), however, on failure returns the error message otherwise 0. More...
virtual const char * | IsSelectVisiblePointsAvailable () |
vtkCamera * | GetActiveCamera () |
| Returns the client-side active camera object. More...
void | AdjustActiveCamera (const CameraAdjustmentType &, const double &) |
void | AdjustActiveCamera (const int &, const double &) |
void | AdjustAzimuth (const double &value) |
void | AdjustElevation (const double &value) |
void | AdjustRoll (const double &value) |
void | AdjustZoom (const double &value) |
void | ApplyIsometricView () |
void | ResetActiveCameraToDirection (const double &look_x, const double &look_y, const double &look_z, const double &up_x, const double &up_y, const double &up_z) |
void | ResetActiveCameraToPositiveX () |
void | ResetActiveCameraToNegativeX () |
void | ResetActiveCameraToPositiveY () |
void | ResetActiveCameraToNegativeY () |
void | ResetActiveCameraToPositiveZ () |
void | ResetActiveCameraToNegativeZ () |
virtual void | StillRender () |
| Renders the view using full resolution. More...
virtual void | InteractiveRender () |
| Renders the view using lower resolution is possible. More...
virtual bool | CanDisplayData (vtkSMSourceProxy *producer, int outputPort) |
| Returns true if the view can display the data produced by the producer's port. More...
virtual vtkSMRepresentationProxy * | FindRepresentation (vtkSMSourceProxy *producer, int outputPort) |
| Finds the representation proxy showing the data produced by the provided producer, if any. More...
vtkView * | GetClientSideView () |
| Returns the client-side vtkView, if any. More...
int | WriteImage (const char *filename, const char *writerName, int magnification=1) |
| Saves a screenshot of the view to disk. More...
int | WriteImage (const char *filename, const char *writerName, int magnificationX, int magnificationY) |
virtual bool | HasDirtyRepresentation () |
| Return true any internal representation is dirty. More...
virtual bool | MakeRenderWindowInteractor (bool quiet=false) |
| Creates a default render window interactor for the vtkRenderWindow and sets it up on the local process if the local process supports interaction. More...
virtual void | SetEnable (bool) |
| Enable/Disable a view. More...
virtual bool | GetEnable () |
virtual void | EnableOn () |
virtual void | EnableOff () |
vtkImageData * | CaptureWindow (int magnification) |
| Captures a image from this view. More...
vtkImageData * | CaptureWindow (int magnificationX, int magnificationY) |
virtual bool | HideOtherRepresentationsIfNeeded (vtkSMProxy *repr) |
| Method used to hide other representations if the view has a <ShowOneRepresentationAtATime/> hint. More...
virtual void | RepresentationVisibilityChanged (vtkSMProxy *repr, bool new_visibility) |
| Certain views maintain properties (or other state) that should be updated when visibility of representations is changed e.g. More...
bool | IsDeprecated () |
bool | GetIsSubProxy () |
bool | HasGlobalID () |
bool | IsPrototype () |
virtual void | Modified () |
