pqLightPropertyWidget is a custom property widget that uses "LightWidgetRepresentation" to help users interactively set a light properties in space. More...
#include <pqLightPropertyWidget.h>
pqLightPropertyWidget (vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
~pqLightPropertyWidget () override | |
pqInteractivePropertyWidget (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
~pqInteractivePropertyWidget () override | |
vtkSMNewWidgetRepresentationProxy * | widgetProxy () const |
Returns the proxy for the 3D interactive widget. More... | |
pqInteractivePropertyWidgetAbstract (const char *widget_smgroup, const char *widget_smname, vtkSMProxy *proxy, vtkSMPropertyGroup *smgroup, QWidget *parent=nullptr) | |
~pqInteractivePropertyWidgetAbstract () override | |
void | reset () override |
Overridden to call this->render() to ensure that the widget is redrawn. More... | |
void | setView (pqView *view) override |
Overridden to show the widget proxy in the new view. More... | |
bool | isWidgetVisible () const |
Returns the interactive widget's visibility. More... | |
vtkSMProxy * | dataSource () const |
Returns the data source. More... | |
vtkBoundingBox | dataBounds (bool visibleOnly=false) const |
Returns bounds from the dataSource, if possible. More... | |
vtkSMPropertyGroup * | propertyGroup () const |
Returns the vtkSMPropertyGroup pass to the constructor. More... | |
void | hideEvent (QHideEvent *) override |
Overriden in order to hide the VTK widget. More... | |
void | showEvent (QShowEvent *) override |
Overriden in order to show the VTK widget. More... | |
void | select () override |
In these methods, we show/hide the widget since the interactive widget is not supposed to be visible except when the panel is "active" or "selected". More... | |
void | deselect () override |
void | selectPort (int portIndex) final |
pqPropertyWidget (vtkSMProxy *proxy, QWidget *parent=nullptr) | |
~pqPropertyWidget () override | |
virtual void | apply () |
virtual void | updateWidget (bool showing_advanced_properties) |
pqView * | view () const |
vtkSMProxy * | proxy () const |
vtkSMProperty * | property () const |
virtual char * | panelVisibility () const |
Forward calls to vtkSMProperty. More... | |
virtual void | setPanelVisibility (const char *vis) |
virtual bool | isSingleRowItem () const |
Determines if the PropertyWidget must be constructed using a single row. More... | |
bool | showLabel () const |
const QList< QPointer< pqPropertyWidgetDecorator > > & | decorators () const |
Provides access to the decorators for this widget. More... | |
void | setProperty (vtkSMProperty *property) |
bool | isSelected () const |
These methods are called by pqPropertiesPanel when the panel for proxy becomes active/deactive. More... | |
Protected Slots | |
void | placeWidget () override |
void | updateVisibilityState () |
Update the visibility state of the different elements of the property widget. More... | |
virtual void | placeWidget ()=0 |
Places the interactive widget using current data source information. More... | |
void | render () |
Safe call render on the view. More... | |
virtual void | updateWidgetVisibility () |
This method is called to update the state of Visibility and Enabled properties on the widget based on the state of isWidgetVisible(), isSelected() and the active view. More... | |
virtual void | setWidgetVisible (bool val) |
Toggle the interactive widget's visibility. More... | |
void | setDataSource (vtkSMProxy *dataSource) |
DataSource is used by interactive widgets to determine now to place the widget in the view e.g. More... | |
void | widgetVisibilityToggled (bool) |
Fired whenever setWidgetVisible() changes the widget's visibility. More... | |
void | widgetVisibilityUpdated (bool) |
Fired whenever the widgets visibility is updated for whatever reason, be it because the panel was selected/deselected or the view changed, etc. More... | |
void | startInteraction () |
Fired by the underlying interactive widget representation proxy, for each respective events. More... | |
void | interaction () |
void | endInteraction () |
void | viewChanged (pqView *view) |
This signal is emitted when the current view changes. More... | |
void | changeAvailable () |
This signal is fired as soon as the user starts editing in the widget. More... | |
void | changeFinished () |
This signal is fired as soon as the user is done with making an atomic change. More... | |
void | restartRequired () |
Indicates that a restart of the program is required for the setting to take effect. More... | |
template<class T > | |
static QString | getXMLName (T *object) |
Description: This static utility method returns the XML name for an object as a QString. More... | |
static QString | getTooltip (vtkSMProperty *property) |
Returns the tooltip to use for the property. More... | |
static int | hintsWidgetHeightNumberOfRows (vtkPVXMLElement *hints, int defaultValue=10) |
Helper method to return value from WidgetHeight XML hint, if any. More... | |
static std::vector< std::string > | parseComponentLabels (vtkPVXMLElement *hints, unsigned int elemCount=0) |
Parse a XML element as a list of label to use for this widget. More... | |
vtkSMNewWidgetRepresentationProxyAbstract * | internalWidgetProxy () final |
Get the internal instance of the widget proxy. More... | |
void | setupConnections (vtkSMNewWidgetRepresentationProxyAbstract *widget, vtkSMPropertyGroup *smgroup, vtkSMProxy *smproxy) |
Setup all the links and events for the given widget and SM property group. More... | |
void | setupUserObserver (vtkSMProxy *smproxy) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | addPropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProperty *smproperty, int smindex=-1) |
void | removePropertyLink (QObject *qobject, const char *qproperty, const char *qsignal, vtkSMProxy *smproxy, vtkSMProperty *smproperty, int smindex=-1) |
void | setShowLabel (bool show) |
void | setChangeAvailableAsChangeFinished (bool status) |
For most pqPropertyWidget subclasses a changeAvailable() signal, corresponds to a changeFinished() signal. More... | |
void | addDecorator (pqPropertyWidgetDecorator *) |
Register a decorator. More... | |
void | removeDecorator (pqPropertyWidgetDecorator *) |
Unregisters a decorator. More... | |
pqPropertyLinks & | links () |
Provides access to the pqPropertyLinks instance. More... | |
bool | VisibleState = true |
bool | WidgetVisibility = false |
int | LinkedPortIndex = -1 |
pqSMProxy | dataSource |
To use this widget for a property group (vtkSMPropertyGroup), use "InteractiveLight" as the "panel_widget" in the XML configuration for the proxy. The property group should have properties for following functions:
Positional:
a 1-tuple vtkSMIntVectorProperty with a vtkSMEnumerationDomain that will be use to show the positional cone or not. WorldPosition:
a 3-tuple vtkSMDoubleVectorProperty that will be linked to the origin of the interactive light. FocalPoint:
a 3-tuple vtkSMDoubleVectorProperty that will be linked to the the focal point of the interactive light. FocalPoint:
a 1-tuple vtkSMDoubleVectorProperty with a vtkSMDoubleRangeDomain that will be linked to the cone angle of the interactive light. Definition at line 25 of file pqLightPropertyWidget.h.
pqLightPropertyWidget::pqLightPropertyWidget | ( | vtkSMProxy * | proxy, |
vtkSMPropertyGroup * | smgroup, | ||
QWidget * | parent = nullptr |
inlineoverrideprotectedslot |
Definition at line 35 of file pqLightPropertyWidget.h.
protectedslot |
