#include <pqMultiSliceView.h>
Public Slots | |
void | updateSlices () |
virtual void | setOrientationAxesVisibility (bool visible) |
virtual void | setOrientationAxesInteractivity (bool interactive) |
virtual void | setOrientationAxesLabelColor (const QColor &) |
virtual void | setOrientationAxesOutlineColor (const QColor &) |
virtual void | setCenterOfRotation (double x, double y, double z) |
virtual void | setCenterOfRotation (double xyz[3]) |
virtual void | setParallelScale (double scale) |
virtual void | setCenterAxesVisibility (bool visible) |
virtual void | setResetCenterWithCamera (bool b) |
Get/Set whether resetCamera() resets the center of rotation as well. More... | |
virtual void | setUseMultipleRepresentationSelection (bool b) |
Set whether selection will be done on multiple representations. More... | |
virtual void | linkToOtherView () |
start the link to other view process More... | |
void | undo () override |
Called to undo interaction. More... | |
void | redo () override |
Called to redo interaction. More... | |
virtual void | resetCenterOfRotationIfNeeded () |
Resets center of rotation if this->ResetCenterWithCamera is true. More... | |
virtual void | updateInteractionMode (pqOutputPort *opPort) |
Try to provide the best view orientation and interaction mode. More... | |
virtual void | render () |
Request a StillRender on idle. More... | |
virtual void | forceRender () |
Forces an immediate render. More... | |
void | cancelPendingRenders () |
Cancels any pending renders. More... | |
virtual void | undo () |
virtual void | redo () |
Signals | |
void | sliceAdded (int axisIndex, int sliceIndex) |
void | sliceRemoved (int axisIndex, int sliceIndex) |
void | sliceModified (int axisIndex, int sliceIndex) |
void | sliceClicked (int axisIndex, double sliceOffsetOnAxis, int button, int modifier) |
void | updateInteractionMode (int mode) |
void | updateDataEvent () |
Fired when the vtkSMViewProxy fires the vtkCommand::UpdateDataEvent The view proxy fires this event at the end of vtkSMViewProxy::Update() when the update executes, not just when the method is called. More... | |
void | representationAdded (pqRepresentation *) |
Fired after a representation has been added to this view. More... | |
void | representationRemoved (pqRepresentation *) |
Fired after a representation has been removed from this view. More... | |
void | beginRender () |
Fired when the render module fires a vtkCommand::StartEvent signalling the beginning of rendering. More... | |
void | endRender () |
Fired when the render module fires a vtkCommand::EndEvent signalling the end of rendering. More... | |
void | representationVisibilityChanged (pqRepresentation *repr, bool visible) |
Fired when any representation visibility changes. More... | |
void | canUndoChanged (bool) |
Fired when interaction undo stack status changes. More... | |
void | canRedoChanged (bool) |
void | selected (pqOutputPort *opport) |
Fired when a selection is made in this view. More... | |
void | picked (pqOutputPort *opport) |
Fired when a port is picked. More... | |
void | beginProgress () |
Fired before doing any actions that may result in progress events that must be reported by the client. More... | |
void | endProgress () |
Fired after performing any actions that may result in progress events. More... | |
void | progress (const QString &message, int percent_progress) |
Fired to notify the current execution progress. More... | |
void | multipleSelected (QList< pqOutputPort *> opports) |
Fired when UseMultipleRepresentationSelection is set to on and selection on multiple representations is made in this view. More... | |
void | nameChanged (pqServerManagerModelItem *) |
Fired when the name of the proxy is changed. More... | |
void | modifiedStateChanged (pqServerManagerModelItem *) |
Fired when the modified status changes for the proxy. More... | |
pqMultiSliceView (const QString &viewtype, const QString &group, const QString &name, vtkSMViewProxy *viewmodule, pqServer *server, QObject *p) | |
constructor takes a bunch of init stuff and must have this signature to satisfy pqView More... | |
~pqMultiSliceView () override | |
const double * | GetVisibleSlices (int axisIndex, int &numberOfSlices) |
Provide access to visible slices positions for any axis. More... | |
const double * | GetSlices (int axisIndex, int &numberOfSlices) |
const double * | GetAllSlices (int axisIndex, int &numberOfSlices) |
Provides access to all (visible and invisible) slice positions for any Precondition: 0 <= axisIndex <= 2. More... | |
const double * | GetSliceNormal (int axisIndex) |
Provide access to slices normal for any axis. More... | |
const double * | GetSliceOrigin (int axisIndex) |
Provide access to slices origin for any axis. More... | |
void | setCursor (const QCursor &) override |
Override for custom management. More... | |
bool | getOutlineVisibility () |
Update Outline visibility. More... | |
void | setOutlineVisibility (bool visible) |
pqRenderView (const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr) | |
pqRenderView (const QString &tname, const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr) | |
~pqRenderView () override | |
virtual vtkSMRenderViewProxy * | getRenderViewProxy () const |
Returns the render view proxy associated with this object. More... | |
void | resetCamera (bool closest=false, double offsetRatio=0.9) override |
Resets the camera to include all visible data. More... | |
virtual void | resetCenterOfRotation () |
Resets the center of rotation to the focal point. More... | |
virtual void | resetParallelScale () |
Resets the parallel scale which is used for a parallel projection. More... | |
virtual bool | getOrientationAxesVisibility () const |
Get if the orientation axes is visible. More... | |
virtual bool | getOrientationAxesInteractivity () const |
Get if the orientation axes is interactive. More... | |
virtual QColor | getOrientationAxesLabelColor () const |
Get orientation axes label color. More... | |
virtual QColor | getOrientationAxesOutlineColor () const |
Get orientation axes outline color. More... | |
virtual bool | getResetCenterWithCamera () const |
Get whether resetCamera() resets the center of rotation as well. More... | |
virtual bool | getUseMultipleRepresentationSelection () const |
Get whether selection will be done on multiple representations. More... | |
virtual bool | getCenterAxesVisibility () const |
Get center axes visibility. More... | |
virtual void | getCenterOfRotation (double center[3]) const |
Get the current center of rotation. More... | |
bool | supportsUndo () const override |
Returns if this view module can support undo/redo. More... | |
bool | supportsCapture () const override |
Returns if this view module can support image capture. More... | |
virtual void | clearUndoStack () |
Clears interaction undo stack of this view (and all linked views, if any). More... | |
virtual void | resetViewDirection (double look_x, double look_y, double look_z, double up_x, double up_y, double up_z) |
Reset/Adjust camera view direction. More... | |
virtual void | adjustView (const int &adjustType, const double &angle) |
virtual void | adjustAzimuth (const double &value) |
virtual void | adjustElevation (const double &value) |
virtual void | adjustRoll (const double &value) |
virtual void | adjustZoom (const double &value) |
virtual void | applyIsometricView () |
virtual void | resetViewDirectionToPositiveX () |
virtual void | resetViewDirectionToNegativeX () |
virtual void | resetViewDirectionToPositiveY () |
virtual void | resetViewDirectionToNegativeY () |
virtual void | resetViewDirectionToPositiveZ () |
virtual void | resetViewDirectionToNegativeZ () |
virtual pqDataRepresentation * | pick (int pos[2]) |
Picks the representation at the given position. More... | |
virtual pqDataRepresentation * | pickBlock (int pos[2], unsigned int &flatIndex, int &rank) |
virtual void | selectBlock (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
Creates a "block" selection given the rectangle in display coordinates. More... | |
bool | canUndo () const override |
Returns if the view module can undo/redo interaction given the current state of the interaction undo stack. More... | |
bool | canRedo () const override |
virtual void | linkUndoStack (pqRenderView *other) |
For linking of interaction undo stacks. More... | |
virtual void | unlinkUndoStack (pqRenderView *other) |
virtual QCursor | cursor () |
Let internal class handle which internal widget should change its cursor This is usually used for selection and in case of QuadView/SliceView which contains an aggregation of QWidget, we don't necessary want all of them to share the same cursor. More... | |
void | setCursorVisible (bool visible) |
Set / get the cursor visibility when the mouse hovers the widget associated with this view. More... | |
bool | cursorVisible () |
virtual void | selectCellsOnSurface (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT, const char *array=nullptr) |
virtual void | selectPointsOnSurface (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT, const char *array=nullptr) |
virtual void | selectFrustumCells (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
virtual void | selectFrustumPoints (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
virtual void | selectFrustumBlocks (int rectangle[4], int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
virtual void | selectPolygonPoints (vtkIntArray *polygon, int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
Creates a new surface selection given the polygon in display coordinates. More... | |
virtual void | selectPolygonCells (vtkIntArray *polygon, int selectionModifier=pqView::PV_SELECTION_DEFAULT) |
~pqRenderViewBase () override | |
void | resetDisplay (bool closest=false) override |
Called to reset the view's display. More... | |
~pqView () override | |
vtkSMViewProxy * | getViewProxy () const |
Returns the internal render Module proxy associated with this object. More... | |
virtual vtkView * | getClientSideView () const |
Return the client-side vtkView encapsulated by this view (if any), or return nullptr. More... | |
QWidget * | widget () |
Return a widget associated with this view. More... | |
QString | getViewType () const |
Returns the type of this view module. More... | |
virtual QSize | getSize () |
Returns the current size of the rendering context. More... | |
bool | hasRepresentation (pqRepresentation *repr) const |
This method checks if the representation is shown in this view. More... | |
int | getNumberOfRepresentations () const |
Returns the number representations in the view. More... | |
int | getNumberOfVisibleRepresentations () const |
int | getNumberOfVisibleDataRepresentations () const |
pqRepresentation * | getRepresentation (int index) const |
Returns the representation for the specified index where (index < getNumberOfRepresentations()). More... | |
QList< pqRepresentation * > | getRepresentations () const |
Returns a list of representations in this view. More... | |
bool | canDisplay (pqOutputPort *opPort) const |
This method returns is any pqPipelineSource can be displayed in this view. More... | |
pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr) | |
~pqProxy () override | |
pqServer * | getServer () const |
Get the server on which this proxy exists. More... | |
void | rename (const QString &newname) |
This is a convenience method. More... | |
const QString & | getSMName () |
Get the name with which this proxy is registered on the server manager. More... | |
const QString & | getSMGroup () |
vtkSMProxy * | getProxy () const |
Get the vtkSMProxy this object stands for. More... | |
ModifiedState | modifiedState () const |
Gets whether or not the source has been modified. More... | |
void | setModifiedState (ModifiedState modified) |
Sets whether or not the source has been modified. More... | |
vtkPVXMLElement * | getHints () const |
Returns the hints for this proxy, if any. More... | |
QList< vtkSMProxy * > | getHelperProxies () const |
Returns a list of all helper proxies. More... | |
QList< vtkSMProxy * > | getHelperProxies (const QString &key) const |
Returns a list of all the helper proxies added with a given key. More... | |
QList< QString > | getHelperKeys () const |
Returns the keys for helper proxies. More... | |
virtual void | addHelperProxy (const QString &key, vtkSMProxy *) |
Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More... | |
void | removeHelperProxy (const QString &key, vtkSMProxy *) |
void | updateHelperProxies () const |
Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More... | |
vtkSMSessionProxyManager * | proxyManager () const |
Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More... | |
bool | userModifiedSMName () |
Return whether or not the user has modified the GUI name of the source. More... | |
pqServerManagerModelItem (QObject *parent=nullptr) | |
~pqServerManagerModelItem () override | |
static QString | multiSliceViewType () |
static QString | renderViewType () |
static pqProxy * | findProxyWithHelper (vtkSMProxy *aproxy, QString &key) |
Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More... | |
static std::string | rstToHtml (const char *rstStr) |
convert proxy documentation from RST to HTML (so that it can be used in Qt) More... | |
static QString | rstToHtml (const QString &rstStr) |
Protected Slots | |
void | onSliceClicked (int button, int modifier, double value) |
virtual void | onInteractionModeChange () |
Called when VTK event get trigger to notify that the interaction mode has changed. More... | |
virtual void | onGenericFilmicPresetsChange () |
Called when VTK event get trigger to notify that the generic filmic presets has changed. More... | |
virtual void | onResetCameraEvent () |
virtual void | onUndoStackChanged () |
Called when undo stack changes. More... | |
virtual void | initializeAfterObjectsCreated () |
void | beginDelayInteractiveRender () |
Triggered by DelayNonInteractiveRenderEvent. More... | |
void | endDelayInteractiveRender () |
void | updateStatusMessage () |
Triggered by internal timer to update the status bar message. More... | |
void | onProxyRegistered (const QString &, const QString &, vtkSMProxy *) |
void | onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *) |
void | updateViewModelCallBack (vtkObject *, unsigned long, void *) |
QWidget * | createWidget () override |
Override to decorate the pqQVTKWidgetBase. More... | |
pqQVTKWidget * | getInternalWidget () |
Helper method to get the concreate 3D widget. More... | |
int | getAxisIndex (QObject *) |
Get axis index. More... | |
virtual void | fakeUndoRedo (bool redo, bool self) |
Updates undo stack without actually performing the undo/redo actions. More... | |
virtual void | fakeInteraction (bool start) |
Updates undo stack of all linked views to record a programmatic change in camera as a interaction. More... | |
Creates a new instance of the QWidget subclass to be used to show this view. More... | |
void | initialize () override |
Overridden to initialize the interaction undo/redo stack. More... | |
pqRenderViewBase (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *renModule, pqServer *server, QObject *parent=nullptr) | |
bool | eventFilter (QObject *caller, QEvent *e) override |
Overridden to popup the context menu, if some actions have been added using addMenuAction. More... | |
Use this method to initialize the pqObject state using the underlying vtkSMProxy. More... | |
pqView (const QString &type, const QString &group, const QString &name, vtkSMViewProxy *view, pqServer *server, QObject *parent=nullptr) | |
Constructor: type :- view type. More... | |
void | setSMName (const QString &new_name) |
Make this pqProxy take on a new identity. More... | |
virtual void | addInternalHelperProxy (const QString &key, vtkSMProxy *) const |
virtual void | removeInternalHelperProxy (const QString &key, vtkSMProxy *) const |
vtkEventQtSlotConnect * | getConnector () |
All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More... | |
Protected Attributes | |
QPointer< pqQVTKWidget > | InternalWidget |
bool | UserIsInteracting |
QPointer< pqMultiSliceAxisWidget > | AxisX |
QPointer< pqMultiSliceAxisWidget > | AxisY |
QPointer< pqMultiSliceAxisWidget > | AxisZ |
QPointer< pqMultiSliceAxisWidget > | AxisXYZ [3] |
QMap< pqRepresentation *, unsigned int > | ObserverIdX |
QMap< pqRepresentation *, unsigned int > | ObserverIdY |
QMap< pqRepresentation *, unsigned int > | ObserverIdZ |
double | NormalValuesHolder [9] |
double | OriginValuesHolder [9] |
bool | ResetCenterWithCamera |
bool | UseMultipleRepresentationSelection |
enum | SelectionModifier { PV_SELECTION_DEFAULT = 0, PV_SELECTION_ADDITION, PV_SELECTION_SUBTRACTION, PV_SELECTION_TOGGLE } |
enum | ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED } |
The modification state of this proxy. More... | |
Definition at line 18 of file pqMultiSliceView.h.
pqMultiSliceView::pqMultiSliceView | ( | const QString & | viewtype, |
const QString & | group, | ||
const QString & | name, | ||
vtkSMViewProxy * | viewmodule, | ||
pqServer * | server, | ||
QObject * | p | ||
inlinestatic |
Definition at line 24 of file pqMultiSliceView.h.
Use GetVisibleSlices() or GetAllSlices(). This method simply calls GetVisibleSlices().
Definition at line 44 of file pqMultiSliceView.h.
0 <= axisIndex <= 2
0 <= axisIndex <= 2
Reimplemented from pqRenderView.
bool pqMultiSliceView::getOutlineVisibility | ( | ) |
void pqMultiSliceView::setOutlineVisibility | ( | bool | visible | ) |
signal |
slot |
overrideprotectedvirtual |
Implements pqView.
Get axis index.
Definition at line 118 of file pqMultiSliceView.h.
Definition at line 119 of file pqMultiSliceView.h.
Definition at line 120 of file pqMultiSliceView.h.
Definition at line 121 of file pqMultiSliceView.h.
Definition at line 122 of file pqMultiSliceView.h.
Definition at line 123 of file pqMultiSliceView.h.
Definition at line 125 of file pqMultiSliceView.h.
Definition at line 126 of file pqMultiSliceView.h.
Definition at line 127 of file pqMultiSliceView.h.
Definition at line 129 of file pqMultiSliceView.h.
Definition at line 130 of file pqMultiSliceView.h.
